Lcd with bad picture
I have two olevia lcd tvs one has a great picture but has a line through the middle of the screen and the other tv has a video problem ,it has a jumping picture that is only viewable at the top of the screen
My sony bravia 40v 3000 has bad ghosting in the first 15 mis of operation
Posted on Dec 12, 2007
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Lt26hvx olevia has vertical and horizontal lines will new main board p506201 fix
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line faults to all LCD TVs; irrespective of its brand and size, will be similar.
Sep 12, 2015 | Olevia LT26HVX 26 in. LCD Television
Multiple colored lines on my tv, then about 2 minutes it shows the picture. I replaced the t-con board, now what?
Unfortunately, lines in the screen is usually caused by a bad LCD panel. You eliminated the T-Con as the problem after replacing it. A replacement LCD panel is very expensive. Buying a new TV is cheaper. Sorry.
Nov 04, 2013 | Olevia LT26HVX 26 in. LCD Television
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
We have a 3 year old olevia television. the other day, a horizontal line appeared on the screen. it is in the middle and goes from the left side to the right side about three quarters of the way. what can...
I'm sorry but nothing can be done to fix the problem because it is defect of lcd panel (screen) that will be replaced but it would cost you approx new tv price so new tv is better choice instead of lcd panel replacement in this tv.
Again, I feel sorry for the bad news.
Jul 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I purchased an Olevia HDTV at NEWEGG.COM about 8 years ago I believe. It has been a fabulous TV. However, a bic lighter spring and flint popped out and hit the top of the screen and I now have two lines...
No,the LCD screen panel can't be repair only can to be replaced,but it is in a limited parts in the productions and 90% important to the whole tv,by replacing the LCD screen panel,will cost the same as a new tv.No the LCD screen panel internal radiation,will continue to leak and slowly getting bigger and bigger.Sorry this tv is not worth as a whole tv anymore.These problems involving with the tvs LCD screen panels or any other tvs screen panels for that mater damages or broken tvs with a screens panels.Will be end up as salvages tv for those electronic's boards for spare parts for other tvs,that it.
Dec 04, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Black line going down middle of screen and one side of picture darker also picture sometime is distorted on bottom
if the line is pixel thin, it could be a bad lcd panel. if it is a wider bar, it may be in the video circuitry. many of these sony tvs had bad panels, and sony has extended the warranty. call up sony with your model and serial # and date of purchase and try to get them to help you out, that is your best course of action. let me know if you need more troubleshooting assitance.
Jun 01, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
WHEN TV IS TURNED ON IT SHOWS WELL FOR ABOUT 10 MIN THEN THERE ARE LINE ON SCREEN BUT THE SOUND IS STILL THERE
It sounds like part of the video subsystem is overheating.
If you see one horizontal line in the middle of the screen, it is probably the high voltage fly-back transformer.
Do you hear a snapping or popping noise when the picture is lost?
Feb 03, 2009 | Olevia LT26HVX 26 in. LCD Television
Olevia 32" LCD TV
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 25, 2017 | iLO 3200 32 in. LCD Television
Televison & Video Logo
369 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
