Freq counter ft225rd (display disappear) problem
Ic msm5564 in the counter unit pb-1734 1735 of ft225rd is defective, could somebody help me with information where to order or at least tell me the new/current equivalent ic number? since at my qth the old ic is not available anymore.
thank you
herman
Kawika-56
  • 233 Answers
SOURCE: AlohaBob PC Relocator....USB Driver for Vista
Microsoft bought Eisenworld. Both the Eisenworld and Alohabob web sites have been shut down.
You will NOT be able to update it.
AlohaBob will be incorporated into the Vista update.
Try updating all your UBS drivers:
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Universal Serial Bus controllers").
If there is some kind of a yellow "Warning" icon superimposed on the 'UBS' icon there is your problem!
If no "Warning" icons then try...
One at a time...
Double click on each of the devices that have 'UBS' in the listings.
Click the "Properties" tab; look for any "Warning" icons
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty driver and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Go back in to Device Manager and Update all the Items listed under "Universal Serial Bus controllers"
Posted on Jul 18, 2008
SOURCE: Need equivalent IC
i made programmer for 89c51. in this use ic ds275. i want know what is the equivalent ic of ds275.
Posted on Dec 06, 2008
SOURCE: Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Posted on Apr 30, 2009
projdoc
  • 2237 Answers
SOURCE: InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Posted on Jul 17, 2009
nethload
  • 22 Answers
SOURCE: My toster does not ssstay in ON position. The IC
An integrated circuit constructed to provide control functions to a toaster oven cooking appliance. The control functions including compensation for input voltage fluctuations, compensation for residual heat due to recycling, audible signal generation, multiple mode selection, safety shut off and others. The integrated circuit also provides flexibility to accommodate multiple models of an appliance in a product line. If you have the tools and the part, you can fix it yourself otherwise to the repair shop
Posted on Oct 29, 2009
Got a playstation display and it has a bluish purple vertical line down the tv but it disappears when any red shows up in thae area of the line any ideas what's wrong with it and if it can be fixe
The display unit is defective, some IC seems to be damaged, it can be repaired from any repair shop, but I don't think the cost will be low, as the display is manufactured by Sony and the spares are not available easily .
Aug 28, 2012 | Sony PlayStation 3D Display - 3D LED...
Galaxy 959 Testing TP3 for AM, LSB, USB with FC-347 or what other freq. counter can be used for this?
An external freq counter will always do a better test then the one on the unit . Do you have an oscilloscope? A function generator will also have a freq counter . Now the ultimate is a spectrum analyzer. you don't need all these but the function generator will work fine.
Jun 23, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Freq. display not correct but radio is on the write freq.
This of no surprise because it is just that a display not a counter.
There must be an alignment pot for the meter display although there will be some doubt if you just align it with out using a frequency counter.
http://cbtricks.com/radios/rflimited/index.htm
you might find more alignment info under the S45 omegaforce as they have similar boards.
hope this helps...goodluck!!!!
Aug 06, 2011 | Magnum 257 CB Radio
The freq counter stays lit at 10.625mnz the claifier knob or the channel selecter will not change the freq counter
This problem, really need to be on a bench to test.. FREE at any good cb shop, to tell you what is wrong.... But most times when a freq counter is not working. Either the crystal is bad, poorly soldered, or its not receiving an input signal. Best way to test is to have a second freq counter external inline using coax.. and check the output of the radio and see if it shows correct or wrong. If it is showing correct they you internal freq counter is messed up. and needs to be check for a bad crystal or solder joints. sometimes even the voltage regulators go bad.. If it is showing a wrong freq on external counter then check the radio's crystal and oscillator circuit. this too can be as simple as a cold solder joint. on the solder side check the small surface mount diode near the PLL, next to the PLL shielded covers. It is normally black these come loose often times too. If you need more help feel free to call or text for more help.
Jan 28, 2011 | Galaxy Radios DX-66V Base CB Radio
When the freq reads 27.225 ch reads ch 26 i can talk to folks and everyboby says it sounds fine don't jump freq or anything just ch select off ???
the freq display can be different from the channel selector display. the crystal in the freqcounter maybe going out or just got out of alignment.... check it with a know accurate frequency counter to determine if its on fequency or not. 000 3174269649
Dec 05, 2010 | Galaxy Radios DX-66V Base CB Radio
The numbers on the phone is not showing...or when somebody calling in
Did you mean there is no display, if so the display unit is having the fault . Open and check if the connecting lines are faulty, remove and reset, if not the display is faulty.
If thers is no caller identification on yourr phone(CLIP)/ or the memory is not showing any numbers, then it is possible that the sub controller IC/memory is defective.
Best to do is to open and solder this section for any moisture, sweat/water. Look for any clogging of dirt, clean ,touch up solder with care not to bridge any circuits.If this wont help the IC must be defective and it might not be very economical to change with the cost of a new one.
Hope you decide with this tip
Aug 22, 2010 | General Electric 25952EE3 Cordless Phone
Mar 13, 2009 | Galaxy Radios DX-2517 CB Radio
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Computers & Internet Logo
255 people viewed this question
David Payne
David Payne
