Question about Samsung YP-K3 MP3 Player
Battery won't recharge
When I attach my MP3 to my computer, it is not connecting, just the battery icon (empty). The battery is not recharging.When I take it of , it just says low battery. I have tried resetting. Brigid
  • 1 more comment
  • Anonymous May 14, 2009
    gahh same with me!! it will turn on, but it says low battery, and then i charged it overnight and it still said low battery. i also tried resetting it but it didn't work.
  • Anonymous May 15, 2009
    same probelm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! its starting to **** me off!!!!!!!!!!!!! i cant do anything without my music!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Same here....Not even a year old and it won't charge. Tried reset as well, charged for hours, did all the tricks found so far....no dice....Starting to tweak me off too....POS thing anyway. My fiance and I liked it up to this point...Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Update your USB drivers on the Computer the MP3 Player will start charging correctly then give it 10 minutes and you should be able to turn it back on.....it works....
Posted on May 30, 2009
My battery for my mp3 won't last long
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 16, 2012 | Coby Audio Players & Recorders
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
Dead not connect charging
Oct 18, 2012 | Apple iPod touch Second Gen (8 GB,...
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
After down loading music player went off won,t recharge
This player is effectively destroyed by using it on a computer that runs either Windows Media Player 11 or Vista. You can try doing a repair in Philips Device Manager, but this is very nearly an obsolete mp3 player.
Nov 27, 2008 | Philips GoGear HDD1830 MP3 Player
How to charge battery
I think it recharges by taking some power from the computer when it is connected. I also use a cell phone charger from the razor series of phone.
Jul 13, 2008 | Naxa Electronics Naxa Detachable PLL...
Recharging?
This product uses a built-in rechargeable Li-ion battery which is charged by usb power. So when you plug it into your Computer or Laptop it recharges with the power it get through the usb port. You can also buy a USB AC Charger for MP3 Players it plugs into your wall outlet and has two usb ports on the bottom to plug into. You can get on at Walmart for about $15.00 called MusicPower
Duet:
http://www.walmart.com/catalog/product.do?product_id=5750794
There are even USB Charger for you Car as well.
Charging Section of the User Manual
This icon will be displayed at the upper left corner of the screen. The following pictures indicate the
charging status of the battery:
(1) When the battery is charging, the battery icon will be changing from an empty battery to a full battery icon to indicate the process.
(2) The following icon will replace the charging one when it is full but the power supply is not being cut off. Which is a Battery Icon with a Lighting Bolt in the center of the icon.
(3) The player will automatically shut off when the power is used up. In this case, all setting will be
saved.
You can get this information on the Nextar website below and the right hand side there section call Downloads click on the MA715.pdf.
http://www.nextar.com/frontend/proddetail.asp?pn=MA715&co=10000309
Later
Nov 16, 2007 | Nextar MA7151B MP3 Player
Samsung YP-K3 MP3 Player Logo
196 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
