Question about GE GSS22JFMWW Side by Side Refrigerator
Freezer not cooling and refer side cooling very little??
My freezer is not cooling properly, I defrosted it and turned it back on. Within 24 hours it had only made 1 tray of ice and the back wall of the freezer is covered in frost. what do I need to do. My beer in the fridge is not that cool either?? Please help!!! Andy
  • 1 more comment
  • Andydena27 Oct 15, 2007
    I did that and found that the defrost coil heater, at the bottom, was burnt out. I have ordered a new heater and once installed, I will let you know if this worked. Thanks for the advice. Andy
  • Anonymous May 12, 2008
    My refrigerator is not cooling and my freezer side is packed with ice.
  • whitsend May 20, 2008
    Same as Andydena27. freezer has frost build-up on back panel inside of freezer and food starts thawing out and other side of refrigerator stops cooling also. unplug and let frig. defrost and it will work about a week until it starts frosting up again. Does this model have a defrost timer? What part should I be looking at to replace? timer,heater, board????? Help
  • 447 Answers
It sounds like its not defrosting this is why the frost is on the back. Remove the back panel and defrost coil with a hair dryer. This will restore the unit to cooling temporarily. I can help diagnose why its not defrosting if you decide to attempt the repair
Posted on Oct 15, 2007
My freezer coils are completely iced over. How do i fix this?
Its defrost problem.You need to first try manual defrost procedure.This will completely defrost the ice.But if again after few hours or few days, same problem is noticed of coils getting iced, then its defrost problem.--------- In defrost problem, mostly fridge section section stops getting cool.It cools but not properly.----- And freezer section works properly. ------------
The manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 11, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer component is frezzing continuously.
This problem is related to defrost.
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.
This will help.Thanks.Helpmech.
May 16, 2011 | Kenmore Side by Side Refrigerator
Refrigerator and freezer not cooling properly even at max settings.
most likely the defrost is not working and it is choked up with ice. Turn off and leave doors open for 24 hours to completely defrost. Then try again, if it works well for a few weeks it will need the defrost looked at.
Apr 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer seems to be working properly, but fridge cant keep temp
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 25, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
FROST BUILD UP IN FREEZER AND REFER NOT COLD ENOUGH
hello.
  • Defrost the freezer
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • If you recently adjusted the temperature control, loaded the refrigerator or are in a humid location, it is not uncommon for a refrigerator to run for 24 hours or more before getting cool.
  • Mar 15, 2009 | Refrigerators
    Frigidaire side by side model# FRS6LR5EW6
    Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks.
    To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain.
    The defrost systems is:
    HEATER-DEFROST
    THERMOSTAT-DEFROST
    Adaptive defrost control
    Start with the adaptive defrost control board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
    Frigidaire - referance model FSC23F7DSB3
    This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A �d� in the freezer temperature window and �F� in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. �d� and �F� will be displayed until the defrost cycle is complete. (approx. 8 minutes)
    Heater / Thermostat
    You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
    let me know if this helps or we can chat if you need more help.
    Aug 09, 2008 | Frigidaire FRS26R4A Side by Side...
    Refrigerator is not cooling, but freezer is working properly
    Usually it's because it's not defrosting. If there is frost buildup on the back wall of the freezer, it's a defrost issue. Most of the time these fridge have a defrost issue, it's because the defrost heater is bad. If this is the case you can get by for a while by manually defrosting the fridge. Take everything out, turn it off, leave the freezer door open and let it sit for 24-36 hours.
    Jul 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE GSS22JFMWW Side by Side Refrigerator Logo
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
