Question about IBM ThinkPad T30 2366 Notebook
Buttons not working
After formatting my thinkpad t30 i now have no use of the thinkpad hotkey as when pressed it used to show all angles of laptop and allowed on off selections for infared control and after searching on web still cant find programs required would be very grateful for any help thanks
    Scholar:
  • 82 Answers
Download the hotkey software from here.
Posted on May 12, 2009
I have IBM thinkpad R60 laptop . I got the laptop formatted few days back and loaded windows XP and MS office . after that the wireless radio is On all time . earlier after pressing fn and F5 th options...
Please follow these steps to make it work:
1. Uninstall the wireless driver using Add/Remove Programs
2. Uninstall the Hotkey utility using its Setup program (uninstall is an option in the Setup app; it doesn't appear in Add/Remove Programs control panel)
3. Restart
4. Delete the Hotkey folders from C:\Program Files\Lenovo\PkgMgr [key step!]
5. Reinstall the Hotkey Utility and the wireless driver (don't reboot if prompted)
Regards.
Jul 29, 2011 | Lenovo ThinkPad R60 Notebook
The t30 light goes immediately from green to orange and won't power up. I just replaced the fan
Remove all power sources(battery and AC adapter) from the laptop. With the power source out, press and hold down the power button for 15 seconds. Then, power on the laptop using the AC adapter only. If this does not work, issue might have something to do with the motherboard.
Jun 09, 2010 | IBM ThinkPad T30 2366 Notebook
Wireless button
The T30 laptops do not have a on/off button that turns the wireless card on.
Once the wireless card driver is installed the wireless card will detect any wireless router and access point within its range. You need to configure the wireless card to connect into the wireless router or access point eg. the encryption, SSID etc.
The Thinkpad laptops have different wireless LAN cards installed, when you install a wireless card driver and it doesn't work, then install a different model wireless card driver. Also make sure the XP or Vista version of the wireless driver matches the Windows version that is installed on the laptop.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
Upgrading processer in thinkpad t30
I have IBM T30 laptop and my Laptop having problem of display its shows when open any files its open like viberation
Feb 28, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad t30 will not start
You should charge the battery longer about four hours. Then the light should be green. Try. If that don't work disconnect the battery and check for anything. Connect your battery again and take a look. If it still isn't functioning please let me know.
Dec 25, 2008 | IBM ThinkPad T30 2366 Notebook
Problem with audio in ibm thinkpad t30,2366-y1b model
T30- no sound altho SOUND MAX drivers installed...
Try Control Panel, Sounds, Sounds (tab), choose a sound toward bottom of list. press the BLACK PLAY ARROW...if BLACK SQUARE appears at the arrow, your sound is installed $\& probably OK...
NOW,,,insert a musiv CD. then press the VOLUME BUTTON, (2nd one over from the THINKPAD button, & you should get sound aplenty !!
Dec 13, 2008 | IBM ThinkPad T30 2366 Notebook
How to get rid of numberlock in ibm thinkpad t30
Hi Ritadeng,
On the Thinkpad T30, the number lock key can be turned on or off by pressing the shift-key and the scroll-lock key. The scroll lock button is found at the top of the keyboard between the PrtSc button and the Pause button.
You should see the light with the arrow and the number 1 inside (just above the F7 key) turn on and off when you press this.
Hope this helps!
David
Nov 18, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
Key board stops responding when windows loads
your mouse freezes; you should only use system restore as a last resort
any virus/spyware you had in the past will come back
turn the computer off(you may have to shut power off pressing on power button)
when you see ibm logo, tap F8 key repeatedly until your hear beeps or a high pitched noise
use option safe mode; use 'most recent config where my settings worked' option in safe mode(use up and down arrow keys to highlght, then press enter)
If that does not work, try another(earlier) restore pt w system restore or install mouse drivers on a cd on another laptop, then
place in cd rom and try to install it on the problem laptop
if this is no good, you should really reinstall windows, back up impt docs, etc.(delete old partition)
that model has a built in restore function by pressing F11 on startup, it will restore your piece to factory condition(along w spyware that comes along w the builtin ibm utility)
I had the same exact laptop, the fan got noisy, so I replaced it w another that was from a good t30, guess what:
"fan error"
Ibm laptops are too problematic to work on
thats why I use dell
if you need more help, msg me or post on here
Feb 25, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
