I have no instruction manual but would appreciate someone telling me whether I should charge them up with headphones switched on or off. I don't want to damage them! Many thank you's!!!
Hi! I've just received a second hand pair of JVC wireless headphones. Should I charge them up with headphones switched on or off please? I don't have an instruction book and don't want to damage them. (This is an amazing website if I get an answer!) Many thanks Brenda
I decided to take a chance and charged them with earphones switched off. It worked fine. Thankyou for having a such a useful site. I'll certainly recommend you to my friends, even though I wasn't helped on this occasion! If I were to come up with a more difficult problem, then I'd willingly pay for assistance.
Posted on May 13, 2009
SkullCandy Double Agent Headphones won't charge or work
What I have seen is that some will just keep on charging for no reason but they wont turn on. What I did is that once I unplugged the headphones from the computer I took the SD card out and I moved the white switch-like thing towards the top of the card. Once I put my SD card in and tried to turn it on again it worked. Try this if your headphone wont turn on but will still charge, it should work.
Dec 25, 2009 | Audio Players & Recorders
I want to connect a wireless headphone to my system, how do I do this
nstall the USB dongle as the manufacturer instructs you and make sure it’s switched on. Next, fire up your headphones (don’t forget to charge them first). Now remember that most headphones have two different start-up modes. The first time you switch them on you’ll need to pair them with the USB computer. This is done by holding the power button on for at least 4 or 5 seconds (you should read the instructions manual to find out exactly how to do it).
After this is done, you’ll need to scan for Bluetooth devices from your PC. Just start up the software and use it to see what Bluetooth devices you have around. The scan should take a few seconds and after finishing, the software should display a list containing your headphones. Remember that other devices such as mobile phones may be detected if their Bluetooth modules are activated during the scanning process.
tb_zoom.gif Select the headphones and go on to the next step. The software should provide you with two choices. You should be able to pair the device as Stereo Headphones or Headset. Choose headset and go to the next step. A pin will be required in order to pair the device. Most default pins are 0000, but you should check the manual in order to be sure.
The headphones will start ringing and you will be required to press the Call/Answer/Power button (do it). Also, a name should be provided for this connection. You can name it anything you like. My software also allows me to place an icon on the desktop and just double click it when I need to connect my headphones with my laptop.
These should be the basic steps when pairing a device for the first time. Now, if I want to connect my headphones with my laptop I can just activate them (in non-pairing mode) and double click my desktop icon to establish a connection.
You can also repeat the steps above in order to pair your device as stereo headphones. After switching on the device, just double click the connection you desire and everything will work flawlessly.
Jul 09, 2009 | Bose 3·2·1 GS II System
Lost instructions on how to sync bluetooth to new phone
If you go in to your phones menu you will find a bluetooth snyc tool. The phone should pick up the signal if the earpiece is turned on. One thing this multifunction button does NOT do is turn the unit on and off. The entire switch itself slides up and down. There are times when you simply don’t want to bother with the earpiece, change wireless headphones, or don’t want to risk accidental calls. So the slider switch is a much easier way to keep track of whether or not the H670 is on or off than waiting for a blinking blue light that may never come.
Have a great day.
Jun 29, 2009 | Motorola Mobility H670 Wireless Headset
2001 Ford Expedition window came off track
You did not mention whether it was a front or rear door? I assume its a front because u stated no screws.
Here are instructions for front door:
Remove the plastic trim from behind mirror(just snaps on).
Remove the window switch panel(just snaps on).
Remove the screw behind the mirror cover.
Remove the screw behind the window switch panel.
Remove the courtesy lamp lens.
Remove the screw in the courtesy lamp housing.
Remove the inside door handle trim cover.
Remove the inside door handle bolt.
Lift upward and then outward to remove the front door trim panel
Feb 10, 2009 | 2001 Ford Expedition
Radio Shack Headphones 900mhz
You can download the instruction manual here.
http://66.77.167.109/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_HEADPHONES&ACTION_PRODUCT_ID=WHP141
Mar 23, 2008 | RCA WHP141 Consumer Headphones
RCA wireless headphones
solution: the directions state: if the TV volume is not tuned to at least 50 percent or more, the headphones will automatically shut themselves off after 4 minutes to limit electromagnetic waves in the room.
it's a simple solution. simply turn up the volume if the headphones stop working. i know, it happened to me as well--before i read that part of the instructions. take care.
Jul 08, 2007 | RCA WHP141 Consumer Headphones
69 people viewed this question
 Grubhead
Grubhead
