Question about Sharp R-242 Microwave Oven
My proline st44 microwave just suddenly went dead. I?ve checked and changed all fuses on the microwave and leads. It comes back again and then goes dead again. The inside door mechanism seems to be intact and no physical appearance of any damage
  • 2 more comments
  • tmohamedali May 13, 2009
    thanks for your reply. no fuse was blown up. but i changed them just in case there were the problem (one fuse inside the microwave and the other in the plug)
  • tmohamedali May 14, 2009
    It's completely dead!
  • marionbagget May 11, 2010
    You said "It comes back again and then goes dead again ". Does that means it cycles on and off or is it completely dead ?
    Did
    Are you saying the unit is blowing the fuses ? It's not clear what yours problem is.
  • 718 Answers
ProLine ST44 950 Watts Microwave
Since this machine is only sold in the UK I do not have a picture to point you to.
The problem is probably a blown thermal fuse. This fuse is located inside the machine and is for detecting overheating and fires. Sometimes age will cause it to fail. It's generally located near the air vent outlet.
If you handy with fixing gadgets you can check it.
Unplug the machine and remove the cover.
You can take an ohmmeter and test it. If it shows open you can replace it. It may be soldered in I am not sure. You can get replacements at an appliance parts store or Radio Shack®. There may be conventional fuses inside so you can check them also.
If nothing else is wrong it might be a door switch problem.
Wear on the interlock causing the crowbar microswitch to short the line and blow
the internal line fuse. The interlock, required by law, contains 3
switches - one switch sends a door-open signal to the
microprocessor, one opens the line and the third crowbars (shorts)
the power leads to the magnetron. If the crowbar switch activates
before the line switch opens, the line fuse gets blown. Just toss the crowbar switch.
Posted on May 14, 2009
Spare parts search ProlineST44 Microwave
your after what i call in australia, is a high voltage fuse, readily availableeither online or from any electronics spares dealers.
Jul 06, 2009 | Sharp R-242 Microwave Oven
GE JES1344SK01 countertop microwave, no power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall, in which case you can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams by entering your full model number here. Once you have the part numbers, though, I would suggest ordering parts here at a much lower cost.
Dec 16, 2008 | GE JES1344SK Microwave Oven
Microwave is dead
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic Dimension 4 microwave model NN-C703BBPQ not working. Display is not illuminated as if fuse has blown. Have changed fuse in plug, but still no visible sign of life. Anything obvious that might...
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
Jul 29, 2008 | Panasonic Microwave Ovens
Gallaxy microwave
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | LG MV-1444Y Microwave Oven
Replacing the fuse of a MCO160UW
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jul 15, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave suddenlt stopped working and I have changed the fuse. Still dead AEG 125 m 8 years old. Looked after
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | AEG Microwave Ovens
My OTC Panosinic Microwave oven is dead. No power to the unit. It is pluged into a live outlet
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
May 31, 2008 | Panasonic Microwave Ovens
Microwave just suddenly stopped working with no other previous symptoms.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
For many brands and models, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Apr 01, 2008 | Microwave Ovens
Goldstar MV1502W
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter lead sagainst the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Mar 20, 2008 | Goldstar MV-1526 Microwave Oven
Sharp R-242 Microwave Oven Logo
410 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
