Question about Toshiba TLP S30 Multimedia Projector
Reset Lamp Hours Timer
How do I reset the lamp hours timer for this projector?  The projector manual says to read the instructions that come with the lamp.  The lamp manual says to read the instructions that come with the projector!
  • 2 more comments
  • discolandia Nov 14, 2007
    reset lamp timer
  • Anonymous Nov 20, 2007
    i have a same problem, with tdp-s8
  • 89carom Jun 06, 2008
    Trying to reset lamp hours on a TLP-X10....Any suggestions?
  • Anonymous Mar 25, 2014
    how can i troubleshoot the projector to see if the lamp is bad or do I need to replace the ballast board?
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
  1. Unplug the power cord from projector
  2. Hold the following keys on the remote
  • On/Standby
  • Menu
  • Input
While holding the above keys, plug power cord back into projector, the lamp timer will reset. When power is turned on "0H" appears on the display to verify the reset process.
Posted on Apr 28, 2009
    Problem Solver:
  • 3 Answers
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "VOLUM -" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
This works for Toshiba TDP T-9
Posted on Jul 11, 2008
This solution works definately with TLPLW15 lamps. May work for others too.
1. Insert the power cord.
2. Turn the main power switch.
3. Press the ^ button on the control for about 10 seconds. (up button on the remote control). This will make the projector to beep. After the beep, press the V button on the control (down button on the remote control) for about 10 seconds.. This will make the projector to beep again for a bit longer. This indicates that the timer is now cleared.
Posted on Feb 11, 2010
    Problem Solver:
  • 5 Answers
I managed to get the lamp hours reset. Below is procedure that is required for TDP EW25 projector for future reference.
Posted on Jan 25, 2011
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How to reset the lamp timer for Sony Projector vpl-px32
      Instructions
        • 1 Turn on your Sony projector after replacing the lamp.
        • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
      • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Jul 07, 2014 | Panasonic PT-44LCX65 Television
    Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
    I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
    Feb 11, 2012 | Panasonic Office Equipment & Supplies
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    Benq PB8220 lamp used for 375 hrs shuts projector automatically
    Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
    Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
    Reset the lamp timer on PJ506d
    Here's the manual
    www.aboutprojectors.com/pdf/viewsonic-pj506d-manual.pdf
    On page 24 in 'Advanced Mode', it tells you how to re-set to factory settings, and that will probably include zeroing the lamp hours.
    If not, there seems to be nothing else there.
    Nov 18, 2008 | Office Equipment & Supplies
    Lamp replacement
    Hi there
    You need to reset the lamp timer.
    Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
    Reset timer
    FROM THE PROJECTOR
    Press and hold the EXIT Button for 3 seconds to display the total used lamp time.
    Then Press the MENU button on the projector during the lamp hour message.
    The press the <-- or ---> button to reset lamp hours.
    Press EXIT to leave.
    Nov 15, 2007 | BenQ PB8220 DLP projector 2200 ANSI lumens...
    Toshiba TLP S30 Multimedia Projector Logo
    9,371 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
