Question about Sharp Televison & Video
I have a Sharp 21V-FP85S: Shuts down after few seconds but the pilot light remains on. I almost soldered all the parts but it did not work. I hope you can help me fix this problem.
I replaced the the power regulator IC and the TV is now OK!
Posted on May 26, 2009
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Tv stays standby mode
There are a few possible reasons
1. Line scan has failed - line o/p transistor
2. Frame scan failed (unlikely)
3. Power supply problem/chopper transistor
4. (and hope it's this because all you need is a soldering iron, good lighting and soldering skill) Dry joints or cracks around line output stage
May 17, 2014 | Sharp CTV 21V-FW150M BLK
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
I accidently turned the pilot off and I can't get it to turn on Williams Model# 2001622
Turn the control valve to the PILOT position and push down and hold it in. Press the Ignitor Button and continue to hold the Control knob down, once the pilot lights. Wait one minute, release the Control Knob and if the pilot remains burning, turn the Control Knob counterclockwise to the ON Position. If after the burners light and burn for a few minutes, you can turn the Control Knob back (Clockwise) to the Pilot position (if you don't want the heater to come on automatically) and the pilot should remain lit.
Hope this helped to get you back up and burning.
Mar 30, 2011 | Williams Heating & Cooling
Lennox G8Q3-90-4 will not ignite the pilot. The
While holding down the control knob for the pilot, you either have to use the pilot ignitor or match light the pilot. Then old the knob in for 60 seconds, before releasing it. If the pilot remains lit, turn the control knob to ON. If the pilot does not remain lit, the Thermocouple or Thermopile may need to be replaced.
Hope this helps you to solve the problem.
Mar 23, 2011 | Heating & Cooling
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
Gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Oct 03, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
GAS VALVE TIMING OUT
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 08, 2008 | Imperial IFS40 Deep Fryer
Shut down
if it shuts down but the indicator ON remains , then check the convergence IC , I beleive it starts with part num. STK-392 of something similar, the other option is to check for a DRY SOLDER somewhere around the POWER SUPPLY.hope this helps
May 03, 2008 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
257 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
