Question about Acer AL1717 17" LCD Monitor
ViewSonic N1900w Base removal
Can you help me with  the removal of the base and stand on my LCD TV please I can get the flat base ioff ok but the stand I cant
5 Suggested Answers
  • 32 Answers
SOURCE: how to remove the base from the monitor
Normally once the base is on its on forever. But you should see little clips that the base uses to latch onto the monitor. You can use a flathead screwdriver and bend the clips inward till the base pops off. Still will be hard though to remove the base. Seems they made that base to stay on.
Posted on Jul 19, 2007
SOURCE: Hoe do I remove teh attached stand on an ACER AL 1913?
Where the footpiece joins up with the screen, you'll find a round cover from left to right which just clips in. carefully squeeze the ends and pull away untill released. under the cover you'll find four screws that holds the footpiece and screen together. Good Luck, jus004
Posted on Jan 05, 2008
  • 11361 Answers
SOURCE: how to remove the base from the viewsonic vx2235wm
You have to remove the two snap-on plastic hinge covers to get to the base mounting screws.
Posted on Jan 10, 2010
  • 11361 Answers
SOURCE: I need to remove the
You need to remove the hinge plastic cover to get to the mountung screws.
Download the service manual here:
Look at Chapter 3 page 19.
Basic LCD monitor and TV troubleshooting guide:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 11, 2010
0 characters
1 Points
Viewsonic monitor manual
Yes. The base stand may be removed. The unit is VESA mount compliant with 4 holes. 100mm x 100mm.
Aug 24, 2014 | ViewSonic VX2025wm 20.1" LCD Monitor
Trying to pack
Few steps to take the stand and base off the 22" ViewSonic VX2235WM
1- Squeeze the bottom of the base to take the base off from the collar
2-This step is very important. The collar has two parts snapped in together, with 3 snap in each side. Carefully use small flat screw driver to take off the back side of collar
Feb 19, 2010 | ViewSonic VX2235WM Monitor
Power shortage monitor black wont turn on? how do i get back off theres two screws but still not separating
You need to remove the two plastic hinges cover to get the stand off then you will see one more screw once the base is removed, more likely to have bad caps, see example here:
Use very thin flat blade screw driver to separate the back cover from the front, starting at the bottom side first,
Jan 24, 2010 | ViewSonic VX2235wm LCD Monitor
How do I remove the base stand fro my Neovo F-17,
You need to remove the two plastic covers the cover up the hinges mounting screws, which are attached to the back of the monitor.
Oct 26, 2009 | Neovo F-17 W (White) 17 in. Flat Panel LCD...
Type and size of screws to attach wall mount to viewsoni 17" lcd
Hi there!
Please refer to Page 7 of your VA1703w user manual for help on mounting this monitor, if you do not have the manual available, you can get it online here:
From what I can tell, you may be re-using the screws that you remove during the listed procedure.
Feb 17, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Viewsonic vg2021m base mount
Gently lay the nonitor, face down, on a table such that it will not be damaged while you remove the base. You will find a curved strip of plastic about 1 1/4 inch wide and 4 inches long. Near the center of this strip, you will find two parallel plastic ridges. These are clips that hold the base to the monitor support post. Squeeze these clips together to remove the base from the support post. I was able to squeeze the rear strip toward the rear of the base and ease the rear of the base off that clip and it came apart ok. It is a bit tricky, but doable. Good luck.
Dec 08, 2008 | ViewSonic VG2021m LCD Monitor
VG930M-3 Taking base of this monitor...
After a chat with a Viewsonic tech and pulling out a lot of screws, this is what I discovered you have to do;
Find a secure place to turn your VG930M upside down, like on an armchair.
Undo the central screw on the base and remove the rotating black plastic plate.  Make sure you know which way it goes back on again.
Remove all the screws on the metal plate, something like eight around the circumference and another two which attach to the LCD support column. (You were never just going to pull that base off!).
Now for the tricky bit! The support column has two extensions that extend down into the base and click into position.  You have to get a flat blade screwdriver and push one of them towards the centre while trying to lift the base just a little away from the support column, so that it is unclipped.
Then you have to do the same with the other extension, while lifting the base a little. The base should now pop off.
Not as straight forward as some screens but achievable!
Good Luck!
Aug 25, 2008 | ViewSonic VP920b 19" LCD Monitor
How do I remove the base of a Viewsonic VX900 monitor?
actually you will be having a projection which locks into the slots of the monitor..
you need to apply some pressure to remove them out of the slots
Jun 18, 2008 | ViewSonic VX900 19" LCD Monitor
Remove stand
we need picture of it, if your not talking about the swivel base.
Dec 02, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
ViewSonic VA720
The VA720 I have has 4 screws from the back: 1 at each bottom corner and 2 in the middle lower at the base. Remove screws and carefully pry the front and back halves apart. They snap together. Usually working the bottom apart first is easiest.
Oct 08, 2006 | ViewSonic VA720 17" LCD Flat Panel Monitor
Acer AL1717 17" LCD Monitor Logo
43 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
