Question about Canon Office Equipment & Supplies
I cannot print in Canon iR2870 photocopier
I am unable to print to Canon iR2870 copier from my PC which has OS Windows XP, thru USB port (1&2 is availbale). I installed the driver from the orignal driver cd. Well, printing is going on with other PCs and it is not woking with only my PC. what could be wrong? pls advice how can I solve this?
  • Anonymous Mar 18, 2014
    unable to scan from printer
    Sergeant:
  • 199 Answers
Mr. rajesh, why don't you try with lan cable it's so easy,
I think in your pc the usb driver (chech in device driver) is not properly installed
Posted on May 12, 2009
While printing or photocopy the print in some copies is tilted in some copies it is straight.
check the paper guides in the casete . or clean the feeding rollers with alcohol
Apr 20, 2016 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Canon ir2016i printing issue
Check if 'secret' option or The ID Management feature is not set.
try different document.
try from another computer
try from another os
try with another cable.
try on another port eg. usb, network,
Apr 04, 2016 | Canon Office Equipment & Supplies
I have a canon ir2016 photocopier which can print documents directly from a computer if connected to it! I have connected it to my windows xp2 pc through a usb port but it is not detected at all. how do I...
As far as I know, Canon IR2016 is stand-alone copier. Printing is optional using Network connectivity. The USB port found at the back is for upgrading purposes only.
Sep 08, 2011 | Canon iR 2016i Black and White Copier
My Canon printer PIXMA MP 800 cannot be3 installed with my windows xp. Help please
ARE YOU UNABLE TO INSTALL YOUR PRINTER AND OTHER DEVICE MOSTLY REASON ARE YOU HAVE NO SUITABLE DRIVER THE BEST STEP THE FIND DRIVER GO TO MY COMPUTER MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE OPEN http://devid.info SITE AND SEARCH YOUR DRIVER AFTER SEARCHING EXTRACT YOUR DRIVER ON ANY LOCATION GO TO DEVICE MANAGER, UPDATE DRIVER SELECT PATH OF DRIVER INSTALL DRIVER TO USE THIS STEPS
May 18, 2011 | Cannon Office Equipment & Supplies
How can i connect my photocopier canon 6220 to a pc in order for it to print
hi mukamose,
use USB cable and see if there is a USB port in your Copier,Be sure the PC is detecting the machine and install the driver.
mastergani
Mar 03, 2011 | Canon NP 6545 Copier
Unable to print in canon iR2870 photocopier
try first to disconnect the USB connector or to unplug and plug the printer...and then wait until there is a wizard appear on your desktop..then just follow the instruction..of the wizard , it will allow the computer to connect to the printer ...
May 13, 2009 | Office Equipment & Supplies
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
Canon Image Class MF4150 Drivers
pls i want to copy for cd the driver about the photocopier ( canon multi function 4150) to install to the pc
Nov 11, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
312 people viewed this question
old marine
old marine
