Question about Irons
Iron surface has a black substance on it
What can I use to clean the ironing surface of a Rowenta power duo?
  • oilden May 13, 2009
    It works!
Clean with a solution of 3 parts Vinegar to 1 part dishwashing deterergent
Posted on May 13, 2009
The bottom of my rowenta focus has a burnt grainy film on it. How do I clean it and prevent it from happening again. I've only used it approx 4 times but it is over a year old.
Rowenta FOCUS STEAM IRON DZ5164 DZ5164U1 user manuals
will give their specific instructions.
Rowenta has a kit, including a paste cleaner for iron soleplates, available from Amazon.
Home made cleaners include a paste of baking soda and vinegar. Rub on, let sit, and wipe with a wet cloth. (Some add a drop or two of dawn dishwashing liquid)
Another home made cleaner is the Mr. Clean Magic eraser, thoroughly wet, and rubbed over the soleplate.
Make sure to wipe the soleplate with a clean wet cloth at the end to remove cleaning residue.
Clean your iron's soleplate while the iron is cold, and don't use something scratchy like a steel wool pad, to avoid scratching the surface.
Aug 11, 2017 | Rowenta Irons
A Rowenta electric iron
clean with steel wool or simply get a new iron with teflon base
Jun 07, 2016 | Rowenta Irons
Glue like substance on the plate of my iron, how do I remove it.
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Oct 07, 2011 | Rowenta Irons
How do you remove Torq screws that have that annoying center pin?
You Have to buy a 'security' torque set. I bought a set of security bits with 50 different types that included the one needed for the Rowenta Power Duo. It was only $9.00 at my local Harbor Freight store.
Oct 24, 2010 | Rowenta Power Duo Iron
Sticky substance on iron plate
get some of the Rowenta remover, YOu put it on your sole plate when Iron is warm. I use an old facecloth, put some on the cloth, then drag the iron side ways or back and forth. Then a clean towel to clean, when it does nto remove, i put some directly on the iron, does a pretty great job.. keep up with the stuff. If you are using fusible things when you Iron, you set yourself up with sggrivation, but a teflon cloth from a quilt store or on line,.It is used for applique and works great.
Jan 12, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
I have a rowenta iron, and began to iron a tablecloth with gold embossing. Now it is stuck on the plate. How do I clean it?
Turn the iron back on, get a sheet of wax paper, iron back and forth on the wax paper it cleans all of the gold and grime off. Then take a Magic Eraser and clean the plate after it has cooled. Won't scratch your plate. Hope this works for you. I have done it often.
Dec 31, 2009 | Rowenta Power Duo Iron
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
Need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
Mar 26, 2009 | Rowenta DZ9080 Iron with Auto Shut-off
Irons Logo
48 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
