Question about Dell E173FP 17" LCD Monitor
Dell E173FP stuck in power save mode
When I turn the monitor on I get a message "In power save mode press any key on keyboard or move mouse" I press keys and move the mouse but nothing happens.  I turned the monitor removed the cables checked the pins and they were fine.  I turn the monitor back on but did not reconnect the cable and I get the floating test screen.  When I plug the cable back in I again get the same error message
  • 28 more comments
  • TPUser Nov 23, 2007
    Exactly the same problem with Dell Monotor stuck in Power Save Mode, but can't get into the PC to Appearance and Themes to fix the problem as suggested above because of the problem with the monitor. Catch 22?
  • hersham dude Dec 26, 2007
    Yes i have the same problem with my monitor tonight. So now that i have no screen to view, how do i correct the problem?
  • John_45 Dec 27, 2007
    Have exactly the same problem with my recently purchased 2004 dell LCD monitor. Worked fine at the shop but not at home. Plugged it into a friends PC (who has a $200+ graphics card installed to run games) and it worked fine. But in my PC it is stuck in power save mode. Is there a patch that can be run on my PC to fix this?
  • dave1229 Jan 02, 2008
    When I turn the monitor on I get a message "In power save mode press any key on keyboard or move mouse" I press keys and move the mouse but nothing happens. I've tried unplugging, installing new drivers, etc. Nothing has worked.
  • Buffyla Feb 23, 2008
    My computer is completely stuck in Power saving mode. It won't even go off. I unplug it for some time and come back the next day, plug it in and I can still hear it running. Even the CD drive will open and seemingly commence,then nothing happens. The monitor reads, warning...your computer is going to power saving mode. I can't get any screen up or nothing. Tried pressing F8 a few times and it would seem like it will boot,then stop. Nothing.
  • jw07 Mar 09, 2008
    My screen stays in power safe mode. I keep moving the move and pressing buttons on the keyboard but nothing happens... help!
  • Anonymous Apr 09, 2008
  • Anonymous Jul 22, 2008
    I just hate that
  • Anonymous Aug 06, 2008
    I've same problem on various Dell Monitor. A solutio is to unplug the cable, plug it on a second monitor working then replug it on first monitro. Lot of times it works but it's a bit boring...
  • primitiveang Aug 06, 2008
    shut the dell XPD 400 series in safe mode.
    when wanting to power back on I get the message "power Save Mode" "Press any key or move the mouse to continue"
    I did this but still nothing
  • yodas lad Aug 17, 2008
    tried the same as lady in waiting getting the same results
  • omarion2nick Aug 23, 2008
    my computer montior keep saying in power saving mode and i cant turn my montior back on
  • mmaanic Sep 08, 2008
    i alos have the same problem ... mine also beeps really anoyingly when you try to restart it..
  • Anonymous Sep 13, 2008
    lcd monitor in power save
  • dtl78 Oct 19, 2008
    I have the same issue... but I doubt it is a monitor issue... or a monitor cable issue... or a graphics card issue. I have two PCs; the PC with the problem is a running Win XP-Pro ( and was running fine for 2 years or more). The other PC (the one I am on now) runs Win2000Pro. The XP box suddenly contracted this "In Power Save Mode" screen, so I did some surfing to figure it out and have done the following things... (1) swapped graphics cards with a known good unit... (2) switched out monitors... (3) switched out monitor video cables... (4) swapped out the PC power supply for a new (and beefier) one... (5) replaced the CMOS battery (as suggested on a different site)... (6) connected different (known to be functional) keyboard and mouse. All failed to clear up this "In Power Save" mode" screen. Though this was not my original configuration, I am currently connected to both PCs via an A-B switch, so I can control both PCs from one keyboard-mouse-monitor and continue testing different ideas. When I switch over to "B", this monitor will go blank and give me the "In Power Save mode" message. I switch back to "A" (and the Win2000 box) and here I am typing away... so the problem is definitely not the monitor or the cables. I have also switched the leads on the A-B switch I am currently using to ensure that this is not an issue. I am open to any "fresh" ideas anyone may have... please help!!
  • montelllll Dec 23, 2008
    when I turn on the computer is says power save mode click button or move mouse I do both things and it still dont work. my monitor only turns on when I click the menu button and thats when it says power save mode. is there any PROPHESSIONALS that can help me.
  • Anonymous Dec 23, 2008
    have gone and got new keyboard and mouse not sure what else to do dont have money to get new monitor or call dell as its £25 just to call em
  • Anonymous Dec 31, 2008
    my monitor stays in safe mode, says to hit any keys or mouse, but that does not work.
  • Anonymous Jan 03, 2009
    MY COMPUTER IS STUCK IN POWER SAVE MODE HOW DO I GET COMPUTER WORKING
  • Kurtis Brown Jan 05, 2009
  • Anonymous Jan 06, 2009
    my comp is stuck in power save mode. checked all connections, but they are all good. replaced keyboard w/ps2, still no joy. un hooked all connections on motherboard and reinstalled back, still no go please help.
  • Anonymous Jan 10, 2009
    same problem, can't fix it.
  • thinkpiece Jan 12, 2009
    i turn computer on and my monitor is blank. i push some little button on monitor and it says my computer is in power save mode. press any key or move mouse. um, nothing happens! my mouse and keyboard are not doing anything! so, please tell me what to do. i hear the tower humming, but i dont know how to see monitor. i unplug cords, turn off and on, press f2 f8, ive tried everything!
  • sisca_stmj Jan 22, 2009
    My LCD still in save mode at 2 second >>???
  • mmkedinger Mar 29, 2009
    The dell dhp04 computer with monitor model E172 FP
    after shut down and rebooting continually comes up with the message on the screen of "power save mode". How do I fix?
    mmkedinger@yahoo.com
  • keithsecker Apr 08, 2009
    I have the same (similar) problem. I have a Dell D620 with a Dell 2nd monitor, everything hass been working fine for 2yrs now, until the other day. I went away from my machine, came back 1hr later and all of my apperance settinsg had reset (background, annoying indows sounds, theme, etc) then I noticed my 2nd monitor was blank too.
    Pressing the control buttons on the front (colour, contract, etc) brings up a message
    "Monitor in Power Save mode, activate via PC".
    I tried pressing the Fn+F8 and going to Desktop - Settings - Extend dual screen thing
    Eventually I just pressed the power button on the front of the monitor. Big mistake! Now the monitor seems completely DEAD!
    Even though Windows (XPsp3) knows the monitor is there (it appears in my dual screen settings) I can not so much as get a flashing green standby LCD.
    I have tried my laptop on 3 other monitors and they are all the same!
  • Anonymous May 07, 2009
    i turn my computer on and the screen pop a message saying on power save mode what should i do
    same problem here with my Dell lcd monitor.
    monitor seems to be receiving the data from computer
    i play with the button in front but i can only receive data for no more than a couple of second,and then it's gone.
    is there something wrong with the configuration of the monitor?
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
Posted on Dec 23, 2008
  • Mercurious Nov 15, 2010
    Before you go out and overhaul your computer with new power supply, cables, memory sticks and a cocktail umbrella, try this simple fix above. I was ready to throw my Dell SZX2210 monitor out the window; spent an hour trying to get the Power Save mode in sync with my computer so I could turn the damn thing off. It seems to happen when I unplug my main computer to use my Lenovo tablet PC for scanning. Anyway, this fix about actually is a FIX. It worked exactly as advertised the first time. Now I have a fix whenever it reoccurs. What a shame it takes individuals figuring things out and having to share online because Dell engineers can't seem to work out the issue in the first place. JLTJJ, hats off to you...YOU'RE TOPS!
  • ZINI X
    ZINI X Jan 05, 2014
    It worked, Thank you:)
What if both the monitor and computer are stuck in power saver? There is no way to get to the control panel. Then what?
Posted on May 14, 2008
How do I get out of the power save mode?
Posted on Mar 26, 2009
This just happened to a friend of mine.Monitor in power save mode,no response from keyboard or mouse.After much frustration broke down and called Dell technical support.It turned out to be a bad memory stick.After turning off the computer we removed one of the memory sticks and booted up again.It worked,no longer in power save mode.Then we did the same thing with the other memory stick.Back in power save mode! Computer is much slower with just one 512 but as soon as we add another memory card it will be back to normal.Hopefully this helps someone
Posted on Nov 06, 2008
  • Kevin Clayburn
    Kevin Clayburn Sep 29, 2011
    great post this was the problem hope more people read it
  • mizzlopez Feb 12, 2013
    wheres the memory stick
I know how to fix this. In Control Panel - Appearance and Themes - Display, pick "Settings".. make sure that in the "Display" pull-down, you select "1. (Multiple Monitors)".
It should work fine :)
Posted on Nov 03, 2007
  • 3 Answers
I had the same problem and found two ways to correct it.
1. You can try hitting the minus (-) button on the monitor. You should get the colorful input test. If it says 2. Digital, then hit it again until the analog comes up. Apparently the analog can get changed to digital which disables or puts to sleep the analog feed (your PC). If this doesn't do it...
2. You will need a laptop. Plug the video cable into your laptop. If the screen does not come up, then close the lid on your laptop. It should come up then. At this point you need to go into the menu on the monitor and reset "all" back to factory. You can then put it back on your pc and it should come up just fine.
Posted on Oct 20, 2010
I have the same problem, although it hasnt been solved by any of your solutions sadly!
I turn my computer on
The screen power button turns green for a second then to orange.. then the message "in power save mode, move the mouse or any key on the keyboard blah blah"..
So i move my mouse and press my keys.. nothing.
I remove the cables (any) cos im so frustrated, switch the switches and unplug the plugs over and over again..
sometimes 40 minutes later it finally turns on.
I have to do this ..every.. single.. time..
and its really annoying, i know nothing about computers and so please help anyone.
thanks !
Posted on Jul 03, 2010
    Scholar:
  • 53 Answers
Well i have fix lots of these most of the time it requires no parts but it is solder joint that need to be resoldered dur to cracked solder joints these were all factory solder by a mechine and have poor solder joint to begin with i have repaired 100s of these issues just by resolder all the joints look close at the bottem of the board and i bet my next pay check you would find bad solder is all the problem you have
Posted on Jun 10, 2009
    Problem Solver:
  • 3 Answers
I tried sol #1, #2, #3, #4, and #5. When I got to #5 Viola! That did it. Thanks replace the bad cable.
Posted on Mar 19, 2010
I have had this problem since purchasing the Dell monitor a month ago. I made sure that on the monitor itself the setting was selected at Auto & it is working now. We shall see
Posted on Jun 11, 2010
I have the same problem, mine got worse with time, initially I could reboot and the monitor would come back on but then it eventurally stayed in power saving mode. My old monitor works fine when I reinstalled it. My old monitor relied on windows to turn off the screen. I think the new monitor has a power saving mode in it that conflicts with windows. I am running Windows 7. There are a lot of posts about this on the internet but I have not seen a solution yet, except to return the monitor.
Posted on May 31, 2010
I did a system restore on my pc from last month when I knew the monitor (Dell 1707fp) and Tv were working.
I'm now back in business.
Posted on Sep 03, 2010
Did you update your Video card drivers recently?.....i'm finding thet the newest nvidia drivers (For 9 series cards) are giving this issue.
Simplest fix...(if this is the case) reinstall an earlier driver...
Posted on Sep 22, 2009
If you have added a memory stick make sure it is seated in the slot correctly. If not check the sticks already installed to make sure they are seated completely and clipped into place. Always unplug your tower before checking your memory sticks.
Posted on Oct 04, 2009
We just had the same problem, and the solution was to unplug both the monitor and computer from wall outlet(120vac power). Wait at least 30 seconds, then plug both in again, then turn them on. Be patient, you'll still get the power saving mode message, but it will boot up anyway. Hope this helps.
Posted on Mar 14, 2010
  • Dell Master
  • 2,008 Answers
Oft monitor repairs differs in many kind of problems a suggestion for handlings is is realy hard to find if something worked correct before and all handlings are present before and worked when this happens and from the one to other time the unit no longer functions, noticed that I had found a small 15 " Dell monitor by the trash a 7 years ago and succesfully have repaired where the first error discovered which started primary in power part of the one print board integrated Dell and I pretty much exactly had the same elements problems like and shows as the lower link.
Albeit it was a different model still like to see the link which shows a similar problem, here are connoisseurs behind the hidden defects in Dell monitors with a lot of knowledge.!! Replace in the first place to be shure the is a a flat dc always the great capacitor to begin and take a little oversized capacitor parts if it can fit and use a 200 watt lamp in serial on the power supply to search for faults in case to test if several damaged parts are replaced to test it first.
The first error discovered which started primary and I pretty much exactly had the same elements ironer shows as lower link.
How to Repair Dell E151FP LCD Monitor
Posted on Apr 26, 2016
For me it is a graphics card issue, I have reverted to onboard graphics and all is fine now, I had unplugged the computer and moved it so a pin must have come out of place as my graphics card is no longer recognised, I switched to VGA socket and all is fine with onboard, altough not as fast a lot less noisy and I have to hit F1 to say I am aware I am not using my graphics card (I'm not a technie so don't know/want to mess with the card until I can pay someone, so yeah anyway that fixed it.
Posted on May 22, 2012
Cured the problem with dell 1713FP 17" LCD monitor by accessing safe mode on pc then apgrading graphics card via the web
Posted on Nov 08, 2008
I seem to get problem with my Dell monitor after opening my computer--which involves unplugging and re-plugging the USB inputs for my wireless keyboard/mouse combo. I gather that I can't wake the monitor because the keyboard and mouse aren't yet awake which leads to a Catch-22.
The general solution has been to plug the monitor into my laptop (in my case I need to also switch my monitor from DVI-D to VGA input), then shift the laptop into multiple monitor mode (Control Panel... Display... Settings... Click the picture of monitor 2... Check "Extend my Windows desktop onto this monitor"). This may bring the monitor to life... or may not, depending on how "confused" it is. Extra hocus-pocus may be required...
For instance, it may help to power down the monitor, unplug all inputs, then power back up. The monitor hovers in a moment of hesitation -- it really wants to "power save" -- then jumps to the panicked conclusion that there's ZERO input and gives a new floating screen with color bars. After that, when plug my laptop in, the monitor listens. Then I switch over to DVI-D input and... there's my long lost desktop.
Who knows, the hocus-pocus on its own might sometimes do the trick...
Cruising other forums I see hints that this trouble may be linked to an underpowered video card, with suggestions to invest in a beefier power supply. In my case, this is likely sound advice.
Good luck all!
Posted on Apr 30, 2008
That's funny, I just had this problem yesterday. I hope you haven't totally trashed the monitor yet, because the problem is probably with the cable that connects your monitor to you computer. At least that was the case for me, and a simple replacement ($10 at office depot) did it for me.  Hope that helps!
Posted on Oct 18, 2007
  • 3 Answers
Remove your ram swap the modules positions reboot it should work fine.
Posted on Jan 23, 2011
    Problem Solver:
  • 6 Answers
Here take a look at this http://www.ccl-la.com/LCDrepair2.htm
Posted on Mar 18, 2010
Shut down your computer, unplug your screen, and the power cable of your pc. Then keep pressing the power button in order to empty the condensators. (you will see the leds going on, and then nothing).
Then replug all your cable, and boot your pc.
Posted on Aug 25, 2008
  • freespool Dec 13, 2010
    solution three worked for me. this is the 2nd time this has happened. so if I have to keep powering down what is causing it to do this after 5 yrs?
SOURCE:
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
Monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
How do I get my computer off power save mode?
open control panel choose power options and you can turn it off
Jan 12, 2010 | Dell E173FP 17" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Stuck in power save mode
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
Apr 25, 2008 | Dell E173FP 17" LCD Monitor
In power save mode
Try hitting the space bar on the keyboard. Does the mouse work normally?
Nov 30, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
58,368 people viewed this question
Clive
Clive
Alun Cox
