Question about Acer Aspire One Netbook 8.9" Notebook
Blank screen...no keys working
My sister has acer aspireone same as me and she turned it on, the power light will come on and charger light, the num lock and caps lock keys flash then turn off but nothing else happens,the screen is blank...I have the same problem. power button is on the screen stays blank. it seems like the screen has gone to sleep.
  • Acer Master
  • 13,433 Answers
Hi
is the acer still covered by the warranty? you can get it repaired for free if it is, its a common fault with these, my friend over here in finland has one of those and it did the same thing, he got it replaced / fixed for free since it was under warranty. get yours fixed also.
Posted on May 12, 2009
  • Ekse May 13, 2009
    The laptop is not starting up its a hardware fault and acer will repair or replace it aslong as your on warranty.
Chromebook reset factory mode
Instructions
Consider what data you still need from your Acer AspireOne's hard drive. Save the files to an external USB device.
Restart the Acer AspireOne's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt-F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5
Use the drop-down boxes to select the time zone and language information for your Acer AspireOne. Restart the netbook when you are prompted to finish restoring the computer.
6
Connect the external USB device to your Acer AspireOne and transfer the data you saved earlier back to the netbook.
Feb 28, 2014 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One NAV50 screen blank
I am not in a position to offer free remote help, but you might help yourself with the link (below). It's to Acer's online community.
If this helps, you can indicate as much - g'luck.
http://community.acer.com/t5/2013-Archives/Acer-aspire-one-model-nav50-Drivers/m-p/57977#M39399
Jun 28, 2017 | Acer Aspire One Netbook
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 07, 2012 | Acer Aspire One Netbook
Blank screen when turned on, then there are 2 lights that flash they both have a lock symbol before them one is with an A and the other is with a 1. Everything else lights up but screen is just blank/black
follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the battery-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 08, 2010 | HP EliteBook 6930p Notebook PC
The acer aspireone screen wont light up when i turn the computer on. the power light comes on, but nothing else happens.
The screen looks to be bad.
Usually the internal lamp burnt out.
If you need to use it, change monitor and try it.
This way you make sure that the video card is working properly.
Don't forget to rate this answer if it helps
Dec 24, 2009 | Acer 22" X223w LCD Monitor
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
You broke it! Try re-installing OS software, hoping you still have the CD disk.
May 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspireone's screen won't turn on. It's just blank.
This is either 1 of 2 problems. Your ram in the bottom of the computer needs to be pushed in all the way, or *********** board is toast. Which is the CPU on the board. And laptops will not allow you to change the CPU. They are hard wired on the mother board. Good luck. Sounds like you might have had some over heating problems with this computer as well.
Mar 05, 2009 | Acer Aspire 9300 Notebook
Blank screen on my monitor. Need help plz.ty.
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem bye
Sep 13, 2007 | Acer AL1916W 19" LCD Monitor
Acer Aspire One Netbook 8.9" Notebook Logo
238 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
