Question about Sanyo DS27510 27" TV
Cable When I hook up my cable I can't get any reception from the cable. What can I do to fix this? Do I need a new piece?
Did you try to connect your tv to another source in the house.if you have cable anywhere else. try to connect your tv to that cable.if that works you might have to buy a new cable for your tv.
Posted on Jan 18, 2008
Television Troubleshooting
1. check your antenna hook up. Make sure the cable is tight. If your antenna is old, you may have to buy a new one. Also check the cable connection to the antenna, that it is tight. You might want to check take the cable off the antenna and see if it is clean from weather wear. If the antenna is inside you might try moving it outside and to a higher position.
2. if you have cable you need to contact their customer support and ask them to check their transmission to you. They can tell if the reception is getting to their box. They may offer to come out to your house to check the connections inside and check the box. Before they do that, ask what it will cost. I did not ask that question and they charged me $60 and only replaced the cable hooked to the box which I could have done.
3. There are antenna's you can buy that will work inside the house. I have one that picks up stations that are 30 miles away. The stations that far away are not always on or good but my point is that the local stations come in very good and clear.
Nov 12, 2013 | Computers & Internet
How do I hook up my tv to regular reception using
you will need to buy a digital converter box to get regular tv. The fcc has changes the way you get tv over the air. check at radio shack and they can get the box for you. should be around $40.00.
Jan 29, 2010 | Vizio Televison & Video
My mitsubishi HD 1080 Picture is Neon Green. We can see all of the shows and everything perfectly, but the colors are black and Neon green. We were trying to hook up some speakers, but have put everything...
I have found that the cable if it is an HDMI cable or DVI is the best suspect. First try another cable or a difrent piece of equipment to feed the signal to your set. Also make sure the cable connector is pushed in and is seated well in its female recepter.
Nov 08, 2009 | Televison & Video
Sony explod,every thing works but the radio
Jun 17, 2009 | Sony Xplod CD Player w/MP3 Playback...
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Broken hook on RM125 engine that holds clutch cable in place
You can see if it could be welded back on. It would need to be somewhere that can weld aluminum. If it is on a cover, replace the cover.
May 29, 2009 | 2003 Suzuki RM 125
My Akai LCT42Z6TM TV does not have a coaxle
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Apr 23, 2009 | Televison & Video
2000 bonneville, one rear cable on the left rear power window
On my 2000 bville, all four of my windows came off. All four had the same problem. the upper and lower cables go around the pulleys then connect to a plastic piece connected to the track. This plastic piece breaks and lets the cable free. I fixed them all by removing motor assembly and reconnecting the cable with coat hangar wire. Kind of a redneck fix, I know, but beat paying 160 dollars per window for a new assembly that would probably break again!! Good luck!!
Feb 26, 2009 | 2000 Pontiac Bonneville
Tv tunner reception
try to update all latest drivers for it software 1st ok and dl latest drivers for your video card ok
Jan 23, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sanyo DS27510 27" TV Logo
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
