T.V. Clicking for 10 minutes before it turns on
Hi we have a Samsung 52in TV (model No: LE52M87BD),Whenever we press the on button at the front of the tv, the tv clicks for about 10 minutes and the red light flashes before the TV finally turns on, this also happens when we turn the tv on from the remote control. It has 2 scart lead outlets at the back and we have moved them around a fair bit between using the DVD & Wii as well as having Sky permanently plugged in. We recently bought a Scart lead box so all the scart leads can stay in all the time. Could this have caused the problem with the delay of the tv coming on? The TV is only 17 months old. Please help. Many Thanks.
  • 221 Answers
Scart leads or scart adapter would never cause such problems. The problem will be in the TV itself. You need to check the power-supply unit at the main-boar. First look for visible cracks at the other side of the board, then you might need to check all the low voltage capacitors at the power unit. In most cases 100 Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} µFx16V located just next to IC causes such a problem. Only one TV out of 430 had actually defective IC itself, and TV was stil working after 6.26mins. So in your case I'd check low voltage part of the power unit.
Posted on May 12, 2009
  • Mike Prince Sep 27, 2012
    Hi. I have exactly the same problem with my Samsung LE52M87BD; it takes about 5 minutes to power on, during which time a relay is clicking on and off, and the red standby LED is blinking in time with the relay clicks. I've removed the Power board and replaced the 2 large 180uF 450V capacitors, but the problem remains. Unfortunately there are no less than 23 low voltage electrolytic capacitors on this board, so I'm hoping you can give me a clue as to which ones I should check out. I'd rather not replace all 23 if I don't have to! There are 3 ICs on my board; ICP801 is located right next to the clicking relay and has 3 caps in its vicinity (0.22uF, 0.47uF and 47uF all at 50V), then there's ICI803 which has a 47uF 50V nearby, and finally there's ICM801 with a 47uF and a 1uF 50V nearby. Thanks, Mike.
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY LCD TV MAKES A CLICKING NOISE, THEN SHUTS OFF ALMOST IMMEDIATELY AFTER IT'S TURNED ON.
The clicking is from the power board relay. It has detected a fault and shuts off. It may be a problem with the power board or one of the other boards is loading it down. Better to have a tech look at it.
May 05, 2010 | Samsung 52IN LCD 5000:1 1920X1080 520DX...
Clicking sounds and delay when turning on lcd tv LE52M86BD
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Jan 09, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
My samsung lcd tv is clicking and wont turn on
Its a common problem with many Samsung LCD TVs. We had the same problem on our Samsung TV. Based on some info on the net we called Samsung Support department ( 1-800-SAMSUNG). After describing the problem and mentioning that I have read on the net that its a common problem, representative asked for the model number and serial number of the TV ( I read them to her from a sticker on the side of TV). The Samsung Rep acknowledged that it was a common problem for my model and few other LCD models and they were fixing the problem without any charge to customer eve though TVwas out of warranty. She took the required info and gave me the ticket/transaction number and forwarded it to a local technician. Technician called next day and setup the appointment with us. Technician came within the 4 hr window that he had promised and changed the faulty capacitor on the power board and was done within 10 mins. Samsung rep had indicated that the technician will determine if the issue was with capacitor or not. If the issue was something else then tecnician will charge the regular service charge to fix the issue.
Jul 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
Hi.. ive got a samsung le40r7 and whenever i try to turn tv on by
Since your tv is a new model it will be IN Warranty. Call 1-800-Samsung and they will set up a service call and send your ticket to a Qualified ASC in your area. Ask if they can send a Samsung Field Engineer to repair your tv. They are nmch more highly trained and you will have a better repair experience.
Jul 04, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Will not power up
Unplug the set for 30 minutes, plug it back in and see if it works.
Jun 24, 2008 | Samsung PS-42C7HD 42 in. HD-Ready Plasma...
Tv repair of Samsung standard tv
I have an LCD HD samsung tv,whenever I am watching my tv the picture goes out but i can still hear it.and have to turn the tv off and on again to get picture back.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
