Question about Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor
I have a amd semporn and accedently overclocked it
I have a amd sempron and accedently overclocked it to much i changed the frequency to its highest setting now the screen will not turn on and the hard drive makes a tik every second then shuts off a minute later what do i do to fix back to normal?
  • 1,959 Answers
Next time you boot, go into your Bios and change the CPU settings back to normal. It's possible you did fry the processor but unless you set it back to normal you'll never know. Best of luck with your problem.
Posted on May 12, 2009
Overclocking processor
download amd overdrive and there you could set clocks and voltages.
May 12, 2012 | AMD Sempron 3200+, 1.8 GHz (SDA3200CNBOX)...
Hello, I would like to overclock my AMD mt30 CPU 1600Mhz25wattTDP 64clockspeed/power ratio to that of a SempronML37 2000Mhz35WattTDP and 57.1 clock speed/power ratio? Do I just change the voltages in...
Due to the way you stated the above John, you seem like a guy that will understand the following;
Yeah know funny thing about overclocking;
1) You may have a good Processor that came off the assembly line that day, or it may be one that just squeezed past Quality Control. Push it too much, and it will fry. Trying to make it hit 2.0GHz all day long, every day, may just push it over the limit. Sure you may have read about, or even heard of someone who did it. How long? How long did the processor last at this overclocked rate?
2) AMD's run H-O-T. Not a good idea to push a Processor with overclocking (Which makes it run MUCH hotter) in a cramped laptop environment, with a low cooling capacity anyway.
3) Ram Memory typically operates at half of the FSB Frequency Rate ('Speed'), that the Processor does. (Front Side Bus)
To overclock you can;
A) Change the Voltage
B) Change the FSB frequency rate ('speed')
C) Change the Multiplier
If you change the Front Side Bus frequency rate too far, the ram memory will not work anymore.
Won't match.
AMD Turion 64 MT-30,
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Lancaster.22_.2890_nm.29
The Sempron you name is a Turion also.
Turion ML-37,
4) You have to have a BIOS Setup Utility that will allow you to change CPU parameters.
See this article?
http://www.ehow.com/how_7335931_overclock-turion-64-compaq-nx6125.html
No mention that overclocking a Processor shortens it's 'Life Span'
No mention that if overclocked too far the Ram Memory may not work.
No mention that an AMD processor runs HOT, and if you overclock you'd better have a lot more than the factory cooling. Plus not a good thing for a laptop anyway because of a laptop's poor cooling design. (Cramped small space, small fan, inadequate cooling thermal module)
No mention that the BIOS Setup Utility in your laptop may not have a CPU Soft option, or options inside that allow you to change the Processor's parameters.
No mention that you should go slow. Change parameters in one SMALL increment, wait 24 hours, and check the system. Looks okay? Change parameters another small increment. Check during a 24 hour period. Keep going until the computer starts messing up, then go BACK to the last parameter that checked out okay
Have I dissuaded you yet?
No?
Just don't want to see someone fry their Processor, or computer.
Okay.
The Turion MT-30 has a clock multiplier of 8 times. (8x)
The Turion ML-37 has a clock multiplier of 10x.
The Turion MT-30 uses 1.35 Volts (DC)
The Turion ML-37 uses 1.35 Volts (DC)
The Turion MT-30's Front Side Bus frequency rate is 800MegaHertz
The Turion ML-37's FSB 'speed' is 800MHz.
What options in your BIOS Setup do you have for changing CPU (Processor) parameters?
State back in a Comment. (Believe top right of your page)
No options?
Then try CrystalCPUID, or ClockGen,
1) http://crystalmark.info/software/CrystalCPUID/index-e.html
2) http://files.extremeoverclocking.com/file.php?f=189
3) http://www.cpuid.com/
Regards,
joecoolvette
Sep 18, 2011 | AMD Turion 64 Mobile MT-30 1.6GHz 25W 1MB...
How to add core volatge? AMD ATHLON LE-1620 on biostar motherboard?
Well, when overclocking, one doesn't usually change the core voltages until _after_ manipulating the bus frequencies, core speeds, and ratios. One should understand manipulation of frequencies before messing with voltages because manipulation of voltages can lead to _fried_ components. Usually one can get a decent overclock just by manipulating the frequencies. Here is a _starter_ website:
http://www.tomshardware.com/reviews/phenom-overclock-athlon,2161.html
Research, research, and research some more before trying to overclock.
Here are some required tools:
http://www.cpuid.com/softwares/cpu-z.html
http://www.alcpu.com/CoreTemp/
http://files.extremeoverclocking.com/file.php?f=103
http://www.cpuid.com/softwares/hwmonitor.html
There are a lot more tools out there, these are just the ones that I use.
I'm running an Intel E8500 (3.1 Gz.) at a stable 3.5 Gz. with _no_ voltage changes. That's not a huge OC, but it's running at E8600 speed and the E8600 costs $100 more than the E8500.
Feb 26, 2011 | Computers & Internet
Can u upgrade the processorto anything high then a amd duron(tm) 1.29ghz
On this motherboard you can use:
AMD Athlon (Highest being the Athlon 1400C running at 1.4GHz)
AMD Duron (Highest being the Duron 1800 running at 1.8GHz)
AMD Athlon XP (Highest being the Athlon XP 3200+ running at 2.3GHz)
AMD Athlon MP (Highest being the Athlon MP 2800+ running at 2.1GHz)
AMD Sempron (Highest being the Sempron 3300+ running at 2.2GHz)
Feb 25, 2011 | EliteGroup K7SOM Motherboard
Fast processor's speed
Your motherboard accepts Socket AM2 for AMD Athlon™ 64FX / 64X2 / 64 and Sempron processors
The board has safe overclocking - so unless you know what you're doing I would stay away from changing any settings manually or you could fry the mobo.
How much memory do you have - more memory can increase speed. Faster HDD
If you want you could go for the Athlon 64,
The Sempron only goes to 2.31 so there wouldn't be much difference in speed.
Apr 25, 2009 | Computers & Internet
AMD temp
AMD Athlon 90C - 95C AMD Athlon64 65C - 70C AMD Athlon64 Mobile 95C - 100C AMD Athlon MP 90C - 95C AMD Athlon XP 85C - 90C AMD Duron 85C - 95C AMD Opteron 65C - 71C AMD Sempron 90C - 95C AMD K5 60C - 70C AMD K6 65C - 70C AMD K6 Mobile 80C - 85C AMD K7 Thunderbird 70C - 95C
Apr 21, 2009 | Computers & Internet
Wintergreen AMD Sempron 2400+
Please go to the following link and download the drivers from there by searching for your product:-
http://www.amd.com/us-en/SupportDrivers/ProcessorSupport/0,,15218_15219,00.html
Jun 22, 2008 | Computers & Internet
Sandrew
There are different ways to overclock, however some methods might harm the CPU I am adding the link which shows the methods. here is the link
http://www.amdboard.com/ocspecial.html
Also please make sure your BIOS supports overclocking
Good Luck
Jun 19, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Amd sempron 2800+
i want AMD Sempron(tm) processor 2800+ free downloads driver
May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Processor
try to configure it in the bios manualy , and set it the right rating 1.8 Ghz so that i will run faster.
or use this: http://www.freshdevices.com/overclock.html
Jan 25, 2008 | Computers & Internet
Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
