Question about Uniden BC92XLT Handheld Scanner
AC Adaptor I have just purchased this scanner from the US (Cheaper !!!) and it has yet to be delivered, but in anticipation, it will be supplied with a power adapter but with an american plug.....will it be safe to use through a basic non-power adjusting plug adapter here in the uk. Is the power lead capable of operating at both 120 and 240 ie american and british power.
If there isn't a switch to select 110 or 220 it should be ok , i had a charger like this and it worked well on 220 altrought I had to plug it with crocodiles clips
Posted on May 26, 2008
Pinout Details for HP C7671B transparency adaptor mini din connector
Cut the mini din wire, you will see four wires inside the sleeves. The red wire is positive terminal, and black wire is negative terminal. Use any 12V DC adapter to connect. The adapter will light up. Good Luck.
May 12, 2012 | HP Office Equipment & Supplies
Need Okaya power adaptor for Protron TV Power Adaptor Model 090-02180-13Bob
Good Day Bob!
This one costs $117.99 and you can purchase it online from the link below:
http://www.powerpayless.com/ac-adapter-replace-yhi-090-02180-13-power-supply-for-protron-sova-a.html
It is an AC adapter replace YHi 090-02180-13 power supply for Protron, Sova, A
Please rate my answer.
Thank you for asking Fixya
Jul 13, 2011 | Protron Televison & Video
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
Im after a bush ac power adaptor for a LCDS20TV011
You could get one from ebay , but they seem very expensive. http://cgi.ebay.co.uk/24V-AC-power-adapter-Bush-1LCD23TV022-LCD-TV-/360224352429?pt=Televisions&hash=item53df0b68ad#ht_2521wt_1094 (It does say make an offer)
Other models may use the same supply and its cheaper, You could check with the vendor if a cheaper one is suitable for the Bush, after all why pay more for the same thing. http://cgi.ebay.com.sg/24V-AC-power-supply-adapter-BenQ-FP231W-Q23W3-LCD-TV-/330393378073 You just need to make sure the current/wattage and the plug on the end are the same.
Jan 17, 2011 | Bush 24v Ac Power Adapter For Bush...
What specification is it for me to purchase
Your part should be Epson AC adapter A241B 15.2v 1.4A 30W. The power cord is a generic type cord common with printers and scanners, it should be easy to find if the power adapter doesn't come with one already. You may be able to find it cheaper somewhere online like Ebay.
Mar 05, 2010 | Epson PERFECTION 1670 AC Adapter 2084614...
Scanjet 4300C
Hope this helps, but there's no specific model number, but here's a description:
Round barrel connecter with a positive center. Voltage regulator, power supply, powersupply, inverter, adaptor, adapter, transformer INPUT: AC 100V and OUTPUT: +12VDC/1.25A (12 Volt 1250mA)
And, a photo:
Aug 25, 2009 | Office Equipment & Supplies
What ac adaptor does the canon 5000F require (New Zealand)?
Specification:
Input :100-240VAC (50-60Hz)
Output : 12Vdc 1.25~1.5A
those are the specs on it.... any adaptor with 12 volts dc. output of at least 1.25 amps will work you can find them at most electronic supply stores... walmart probably even sells them
Mar 16, 2009 | Canon CanoScan 5000F Flatbed Scanner
AC adapter for SANYO Xacti
Radio Shack has a replacement adaptor for the Xacti VAR-G9,
You need the following 5V DC (Five Volts Direct Current) 2.0A   (Minimum 2.0Amps - more is OK, less is not)
The TIP is positive.
The unit I purchased from RadioShack is P/N273-1696 and works great for my Xacti.
Make sure you don't have any little kids who may change the switch setting from +5V to something larger.
Also pay CAREFUL attention to the TIP  voltage on the adaptor. The Sanyo takes a + Tip.
There are other cheaper solutions as well, but this unit can be re-used with other gadgets.
My Sanyo VAR-G9 AC adaptor failed after TWO DAYS out of the box, so I can't recommend buying a Sanyo VAR-G9, until Sanyo fixes their manufacturing problems with the units.
--Ross
Oct 16, 2008 | Mintek Portable DVD/CD Player w
Spare Part
you can build your own using any old 12v 1250ma+ psu
guid on this site
kpm
Apr 18, 2008 | HP Scanjet 5470c Flatbed Scanner
Uniden BC92XLT Handheld Scanner Logo
191 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
