Question about Proview PL913S 19" Flat Panel LCD Monitor
LCD display Proview
I have a 19' Proview LCD display. Recently it startet turning off by itself after working for 4-5 sec.We connected it to another pc and the display acted the same way - it worked for 4-5 sec, then it turns off. We have to press the on/off buton to turn it on, works for 4-5 sec and then goes black again.
  • 5 more comments
  • chapman1 Nov 06, 2007
    I am having the exact same problem. my proview lcs keeps shutting itself off after about two sec. I unplugged unnecessary plugs like my speakers and printer to see if it was a power problem and ran a full system scan for a virus. nothing. I also unplugged everything for about ten min. and put it all back on and nothing.
  • Anonymous Nov 12, 2007
    I have the same problem!! Proview claims they havn't had any problems with this monitor but this proves different. I called my local TV guy and he said it could be the backlight. I'm trying to find a manual on line to help me change the backlight. Pro view wants $100.00 for me to send it to them!! I just paid $200.00 for it a year ago!!
  • calorado Nov 26, 2007
    Just started having the same problem of monitor autonomously switching off after 2 seconds. By cycling the power button on the monitor after each auto-turn-off while I tried to shut down the computer, it eventually seems to stay on. Almost like it needs to warm up. Do not know if it will get worse in the future.
  • bosaburn
    bosaburn Mar 22, 2008
    I was using my computer the other day and I noticed that the monitor was flickering a little bit.at first, I blamed it on the constant construction that is going on in out\ apartment complex, but then all of the sudden the screen went black but the power light remained on and lit up. I pressed the button to turn it off and then on again. the screen came up and then started to flicker and after around 4 seconds, went black again. I tried this several times and even un plugged both wires and plugged it back in to my computer and then on another. still the same thing is happening. I reinstalled the driver that I thought I needed and nothing worked. Normally I am the guy that sends in rebates and buys insurance or saves the actual box in which the product came, in case I would ever have a problem. The one time I need those things, I don't have them. Is there anything that I can do to get a new monitor out of this without the box and warranty? Or is there a way for a mechanically inclined person such as me to maybe pop the cover off and tweak a wire to get \it working again. please email bosaburnii@aol.com . thank you : )
  • Anonymous Jun 12, 2008
    Yeah...exact same thing started today...mine is a TV/monitor and I use it with PS3. Screen just went dark but audio is still there. Power off and back on again and image comes back perfect for only a couple of seconds then black again. Changing the source on the tv also brings image back momentarily. Doesn't make sense to me that it be backlight or anything to do with the bulbs because the image does appear.
  • Anonymous Jun 22, 2008
    Exactly same issue with PL916S 19 inch silver LCD monitor. Looking at ordering and replacing backlight
  • Anonymous Jul 20, 2008
    pl913s prowiew
  • 593 Answers
I would look on the power supply board and check for any capacitors that are bulged or popped. They look like little barrels with a cross or 3 line star on the top. This is the vent and it should split before the capacitor pops like a firecracker or blows its top off like a bottle of shaken champagne. I bet you have 8 bulged or popped caps on the P/S and they can be replaced at about .30 cents a piece and a soldering iron. Just make sure you get the right farrad ratings, like 470 micro farrad and get them rated to 105c for heat resistance. Most are 25V but you can use the more common 35V safely. If you are going to toss the monitor in the trash, do yourself a favor and at least spend 30 minnutes looking into these. It may save your monitor. If the lamps even light for a few seconds, its not the lamps. If the inverter is bad, you would get no light. the starting of the lamps takes lots of voltage, keeping them going is about 1/4 of the start voltage so if they start, the inverter is doing its job.
Posted on Apr 08, 2008
  • 4 Answers
I've got 2 identical 17 inch Proview MA-782K s with the screen blanking after a few seconds problem, just done one with new caps and its all running well again.
Pulled the other to bits and its completely diiferent in side.
Done the caps & still the problem remains, pulled the whole screen to bits right down to the light tubes and LCD taken out.
Put the tubes in the other monitor and they work perfectly so tubes ok , so most likely its the invertor
Put the invertor on the other Monitor , even though different design inside still the same connectors.
and the screens blanks out so it has to be the Invertor.
As the invertor has a PSU, a trigger section and a pair of high volts sections, with both tubes going out its either the PSU or the trigger thats at fault, unlikely both high voltage drivers section going down together.
Hope this info helps someone. now off to dig deeper out whats going on.
Maybe try some other caps
Ceedy.
Posted on Nov 21, 2008
  • 558 Answers
The problem here is simple no one knows how to replace the caps properly,
1 you must de-solder cleanly and leave little solder behind there is a tool to **** solder off the board for the few sec it is hot for 7 dollars it is worth it
2 cap replacement is important the negative side is marked on the cir. board always. the caps must be placed back exactly as they were taken out or you will damage the transistors and other components on the board. so 1 at a time.
3 you must be careful to solder only the pin to the hole area this is not a sandwich...
4 inverter lamps last 60000 hours I have only had to replace 1 lamp in a laptop in 10 years of service work. and yes the ends get burned just like those big 4 foot jobs in the ceilings at schools and office buildings.
5 if you can find 105 c temp caps great more power to you but 85 c caps work just as fine unless you have the house open and work in cuba.
Posted on Nov 03, 2008
    Problem Solver:
  • 7 Answers
Dude ck this out if you don't know how to solder you will, do more damage then good. To much heat will ruin a circuit board there's a plastic coating that melts from the heat. So be extra careful!!! I do like the info about the caps being swollen but that doesn't always solve the problem have not tried to take lamps from scanners and modify to fit think I'll try that Let you all know in a few days if it works.
Posted on Jun 29, 2008
I ordered the capacitoes from mcm.com after driving to every radio shack in town. i bought a few extras just in case i did something wrong. i unsoldered the old ones, but did not really pay attention to which way they were plugged in. i replaced the old with the new with ease but when i put it all back together and plugged it in the power light went on for a second. the screen was still black but if i played around with the power cord plugged into the back, i could kind of see the screen dimming up a little bit. i figured that i just resoldered something too loosly and gave it another try. this time i tried to figure out which was the capacplugged in. it said the the stripe on the capacitor should be on the dark die of the mark on the board that they solder to. i did that, put it together and plugged it in. this time absolutley nothing. my question is, is it possible to mess the whole thing up if some solder gets on the other parts of the circuit board? was i determining the placement of the capacitors wrong? in actuality, the capacitor plugs in to the board on top of cirlces that have white shaded on one side and nothing on the other. the side with nothing is the color of the circuit board ( brown ) so maybe that is the side i was supposed to match with the stripe on the capacitors. all that i know is that so far it has cost mearound 30 dollars to buy parts and a soldering iron and i have spent at least four hous of time taking it apart and putting it back together. i should just go buy a new one at this point but none of the new capacitors appear to be blown out or bulging. so if some one could tell me exactly how the capacitors go in, i might try to re do it one last time. i could take a picture and post in on myspace if anyone thinks that may help. in the meen time. thank you and good luck !
~gary bosaburnii@aol.com
When you screen goes off after 3-4 sec. It's more likely that the life of your Neon Lamps is over (Probably the lower pair). Not the inverter.
A defective Inverter would not light it up at all or for a maximum of half a second.
When you tunr it ON, try to see if something completely white seems to appear slightly pink (Ex: the "No Signal" over the blue screen should be in clear white.)
BTW, Your monitor didn't go off. Only the backlight is not working. Just take a look closer, You'll see the image is still there but All dark.
I repair LCD for years.
Unfortunately, its the worst case it could have happened to you.
Since the whole screen doesn't sells for cheap, you'll need to change them yourself and *fit* em into the old metal case that goes into the backlight assembly.
Warning : Its really risky to try to change it by yourself *IF* you find the right lamp for replacement of the original.
Even Bending the Image Panel flat wires can permanently damage your LCD. (Vertical white line).
If you dont know what you are doing, DONT DO IT.
Posted on Mar 03, 2008
I READ BEFORE THAN THIS LCD MONITOR HAVE PROBLEMS WITH THE CAPACITORS OR THE INVERTER. THE CHEAPEST SOLUTION IS CHANGE THE CAPACITORS FOR NEW ONES. MORE INFORMATION LOOKIING AT GATEWAY LCD PROBLEMS. ITS NOT THE SAME BRAND BUT REMEMBER , ALMOST ALL MONITORS WORK EQUAL.
Posted on Dec 08, 2007
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Proview fv-926afw 19'' LCD flickers and buzzes
If you have a capacitor tester.. i'll be much better at least you would know which caps that actually failing..
I would replace all the caps if you dont have the tester.. and while your at it. try to resolder connections and some parts like transistor etc.. maybe they have "cold solder"
May 04, 2009 | Panasonic Computers & Internet
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Colored lines on screen
This may be caused by the death of a display driver circuit and these might be integrated with the display itself.
The pixels on the screen are controlled by an X-Y matrix and the matrix may have signal lines that are somewhat shared for different screen positions.
I doubt that this is DIY project and the failure can only be located by an equipped and trained tech.
Feb 02, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
LCD Monitor goes off after 2 sec.
Check all cracked solder joints and resoldered and check two smd transistors near the inversors good luck
Aug 11, 2008 | Proview PL913B 19" Flat Panel LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Jan 18, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor turns on then off.
I bought Same Monitor Dec. '06 and Jus last week It faded to black and then now doesn't power on. my protection plan sent me a new one that powered on for like 20 secs. So now I have another one coming. I also knows its not my PC cuz I'm using a monitor right now. I think Proview and Circuit City Sucks
Jan 11, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL913S 19" Flat Panel LCD Monitor Logo
1,830 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
