I have a lg dvd\hdd recorder. mpdel no rh2t160.
Problem dvd ejects and closes at odd times and now will not stay closed.
I put a dvd on tray, press close button,
dvd tray closes then opens straight away..
any help would be appreciated
regards Wally
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.
I'm not familiar with your exact model, but usually when this happens, the loading belt is at fault. There are microswitches inside which determine the limits of the tray movement. There is one that is activated to indicate that the tray is out and another to indicate that the tray is in. If the belt slips, the inner may not be activated and the system will cause the tray to come out. Try replacing the belt.
have a samsung dvd hd755 when turning it on it flashes hdd and a load sign and nothing happens i...
(More)
have a samsung dvd hd755 when turning it on it flashes hdd and a load sign and nothing happens i turn it of and on and can get the open sign but again nothing is happening
