Question about Acer Aspire 5610-4648 Notebook
Can not connect to internet
Cannot connect to internet, wireless or wire. T604 has exclamination in yellow triangle. Disabled T604, still can not connect. Reloaded lan driver. Still will not work
  • Filip Eastman May 11, 2010
    Hello I need little more information to help you.
    1. what os does you use? xp, vista?
    2. what is your routers name ?
    3. what do you mean "disabled T604? do you have a DLINK?
  • 413 Answers
Go to control panel and then systems and then hardware and then click on the device manager. Listed under network adapters check to see if it is working properly. If it is not enable, enable it. go back to your control panel and then double click on network connections.
on the device right click to go to properties>>now in a new window
Click on tcp/ip and click on properties make sure that ip address and DNS server address automatically and you should be connected to the internet.
If you dont have ip address that might be required you may contact the service provider or
ISP(internet service provider)
Fixya is glad to help you!!!!
Posted on May 12, 2009
  • shankar anand jha
    shankar anand jha May 12, 2009
    A feature of Microsoft Windows, APIPA is a DHCP failover mechanism. With APIPA, DHCP clients can obtain IP addresses when DHCP servers are nonfunctional.Due to this you see yellow triangle it means limited connectivity
Connected to the network but no internet access
tried to hooked up the LAN cable directly to the modem bypass the router if you can get an internet access there.
Nov 02, 2012 | TP-LINK TLWR340G Wireless Router
Connecting acer c100 to internet
hi, have you added the device (c100) to the router access list under wreless settings , the clue would be a yellow dot or triangle in the wireless logo on the c100 showing restricted access?
Jul 07, 2012 | Acer (91.48R28.006) for TravelMate C100...
I have a new dell 1545. I was able to connect to the internet for the first few days. I have bought a linksys usb that has given me an extra bar for signal. I have installed a netgear router which has...
Try linking your ethernet cable from your router to your notebook. If it allows you to connect via ethernet port, it definitly your wireless.
1st go into control panel, then Network and settings, then Manage wireless networks. Remove all other wireless networks on your computer apart from the one you are trying to connect to.
Once this is done, Go back to your control panel, Network and internet, then click connect to a network. Disconnect from the network you are connected to and then reconnect. This should solve your problem, please let me know how you get on and if you need any further assistance, please rate it this was of any help, thanks
Mar 07, 2011 | Dell Inspiron 1545 Notebook
Router connected fine... not allowing my laptop to pick up wireless signal. not an internet issue as I have connected primary computer via wire and it works fine. need some troubleshooting ideas to...
In your router settings, look for something like "wireless radio" and make sure that is enabled. It sounds like your wireless is disabled.
Or
On your laptop, your wireless card may be disabled. Are you able to scan and locate other wireless networks on your laptop?
Feb 27, 2011 | Computers & Internet
My toshiba laptop does not work on a lan. The icon
When you look at the Manage Network Connections link on the Network and Sharing Center you do not see
Local Area Connection?
Do you see Wireless Network connection?
You need to check the device manager to see if the card has been disabled.
It should show two entries with no red or yellow marks. One for wireless (WLAN) and one for wired (Ethernet)
Apr 11, 2010 | Computers & Internet
Toshiba satellite wifi not working
Hello
You might have physically switched on the adapter, but in Windows it is still disabled.
In Windows XP, click the start button, look for CONNECT TO (don't go in the all programs menu), and click SHOW all connections. A window opens showing all the connections available. If the wireless connection icon displays a red X crossing it, it is disabled.
To reenable it,
Point the mouse cursor to the wireless connection and right click mouse button. Click enable or repair.
One question though. If your computer is toshiba, you must have installed the configFree software that came with it.
If so, look to the left right of the task bar and click the ConfigFree Icon. Choose Connectivity doctor. It will diagnose your connections. If one is disabled or has a problem, a yellow triangle with an exclamation mark ! will appear on the connection.
Use the device setting thumbnail, select your WIFI adapter . A button at the right bottom side, will show either Enable (if your adapter is disabled), or disable i(f adapter is enabled). With that button, you can toggle between enable and disable. After that click the close button, and hopefully you will be able to surf the web.
Hope it helps
Hope it helps
Aug 21, 2009 | Dell Inspiron 6400 Notebook
Intermitnent wireless connection problems
There are two reasons for fluctuating wireless signals .
1. There is interference by way of microwave, hard cement walls, cordless phones, etc 2. The firmware of the router needs to be updated .
Either of these is the reason for your problem. Hope this helps .
Thanks
Ranjit
Aug 10, 2009 | D-Link DGL-4500 Wireless Router
Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Feb 06, 2009 | Acer Computers & Internet
No Internet
You may try checking the network driver of your computer.
1. click start --- right click "My computer / Computer".
2. click Manager then look for device manager.
3. under device manager on the left column. Look for your network adapter if it has a yellow question mark or a red x mark.
Red X - disabled.(right click then select enable)
yellow mark - driver is not installed/corrutped (you need to install the driver online or from the cd that came with the computer)
4. Restart
Now, if the issue still the same. Try a different computer and check if you can connect to the internet. If the issue still the same. Call you Internet service provider to check on the connection.
Keep me posted.
Thanks.
Oct 26, 2008 | Dell Inspiron 1000 Notebook
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Acer Aspire 5610-4648 Notebook Logo
135 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
