Question about Hoover Nextra HNF 3157 Front Load Washer
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
I had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
Posted on Aug 30, 2009
    Problem Solver:
  • 11 Answers
You must chek if heat ir not, I think the heater not work.
Posted on May 12, 2009
Machine will not finish any wash cycle, It stops, illuminates END light and beeps? Is there a reset or is this at the end of it's life?
Hi, quite often cycles are not finished because the drain pump has an intermittent fault. It may pump ok at the start of the cycle but towards the end it's had enough and stops. Leaving water in the bottom of the drum. If this is similar to your machine's symptom then I would be checking the pump. They are cheap to buy and easy to fit.
Hope this helps you.
Oct 04, 2015 | Washing Machines
Hi - my washing machine keeps f05 coding & the green start light won't come on
Is the outlet pipe blocked. Check this as sometimes the water gets backed up and this is sensed and an error is displayed
Mar 28, 2015 | Washing Machines
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
May 06, 2012 | Hotpoint Washing Machines
I have an F&P MW612 washing machine that stops at the start of the spin cycle leaving water in the machine. After pushing the pause button, looking inside, closing the lid and restarting I've heard...
Something may have been stuck in the drain pump impeller creating the clanking noise. This is a serious problem that can lead to the burning out of the motor controller module, the machine's "brain". It has been found that a short circuit is imminent on a leaky drain pump which can eventually burn out the motor controller module.
Empty the machine then lay it's front on a padded floor/surface and check the drain pump including the diverter valve where both the drain pump and the recirculation pump connect from. Replace the drain pump if damaged or leaking to avoid further damage to the motor controller module.
Fault Code Reading on Fisher and Paykel Top Load Washing Machines
Aug 23, 2011 | Washing Machines
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Not washing at all on any cycle
Sorry, sounds like your Circulation Pump is faulty/worn out.
If your machine is not over two or four years old then maybe you have a simple blockage.
If your machine is old, a new pump can be half the price of a new machine.
Hope this helps.
Apr 16, 2009 | LG Dishwashers
Hoover Nextra HNF 3157 Front Load Washer Logo
890 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
