Question about Garden
I have my cub cadet 2100 series in the shop. The mechanic says the problem is the coil and that the engine has to be pulled to get to it. Are they shooting straight w/ me? I thought the replacing coil would be easier than that. Thanks' Don/ Vicksburg MI
  • townsd May 12, 2009
    No other components are going to be replaced. he said that do to the unique PTO he has to lift the engine.
  • 1,000 Answers
Unless there is a particular reason he can not remove the flywheel shroud to gain access to the coil, there should not be any reason to remove the engine.
The only reason to remove the engine would be to gain access to a component he can't get with the engine installed.
Was there anything else he was going to replace?
Regards,
Posted on May 12, 2009
  • Bruce Bracey
    Bruce Bracey May 13, 2009
    I see, if the PTO is in the front, he will more than likely have to lift it in order to remove the flywheel cover. He is correct if that is the case.
    Regards,
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling
Because I didn't know they used 2 belts in the diagram on parts tree.com . I bought the 79" belt and not the 78" belt.
Aug 22, 2014 | Cub Cadet Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
you need to change thr hydr fliud in the transmission and the filter
Cub cadet lt 1042
Some of those cadets (like those with the Command 20) have a compression release mechanism on the cam which is intended to make that engine crank easier but disengages once the engine fires up. It's a plastic part and is prone to break, resulting in a lot of strain on the starter motor. Interesting design, bad materials. Sometimes the engine will start anyway but this is not a good idea to operate this way. Pull the valve cover. Look at the motion of the exhaust valve when you turn the engine by hand. It will look similar to the motion of the intake valve if this part is broken. If it's working correctly, you should see the exhaust valve open slightly just after the intake valve closes. I'll attach a video to show what it looks like. Replacing the bad cam is a bit of work but not terrible.
Oct 04, 2013 | Cub Cadet Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
Engine shuts down after running for awhile
Could be a bad coil. I had a Cub Cadet that would shut off when it warmed up. After it cooled, it would start up just fine. I ordered a replacement coil from a local dealer and replaced it. It works fine now. Unless you are comfortable with mechanical repairs, you might want to take this to a qualified small engine repair shop.
Jun 22, 2012 | Garden
Service manual for Cub Cadet, series 980 mower
http://shop.ebay.com/i.html?_kw=Cadet%2C&_kw=service&_kw=manual&_kw=Cub&_kw=series
26 for sale on ebay
Jul 05, 2011 | Cub Cadet Garden
I need a wiring diagram for a 3165 Cub Cadet Lawn tractor. I need to know where the 2 green wires in the wiring harness go.
My name is Dane and I am going to try to help you solve your problem. Here is a link to where you can find your 3000 series manual. The wiring schematics start in chapter 13.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Dec 04, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Replacing governor on Cub Cadet 1225
I have a cub cadet 1864 and the governor is out of control, the engine will race a high speeds. When i pull back the governor arm and hold it it run normal. Can some one help
Apr 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
167 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
