Question about JVC Cybercam GR-D90 Mini DV Digital Camcorder
Error indication E04 eject and re-insert cassette ?
I have tied several times to do what it says but it still doesn't work. what can i do?
    Problem Solver:
  • 5 Answers
Hi, when you get an E0 type error it is time to take it to a technician.
Posted on Aug 17, 2008
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
Re-insert the cassette error message
SMACK THE CAMERA ON EITHER SIDE REAL HARD
? what does it mean plz?
can you explain for me plz?!!
Apr 12, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Mar 28, 2009 | Canon ZR300 Mini DV Digital Camcorder
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
JVC GR-DX27EK/JVC 700X DIGITAL ZOOM
my jvc grdx27ek camcorder won't load cassettes. each time it says error E04 and asks to eject and load tape again. It also has habit of showing that lens cap is on when its not..........itsssssss infuriating that a fairly new but out of warranty product should behave in this was.....sounds like built-in obsolecence.....? Can anyone helllppppp me here?
Jun 15, 2008 | JVC GRDX77 MiniDV Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
JVC Cybercam GR-D90 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
