Question about GoVideo Rave-MP ARC5.0 MP3 Player
MP3 player something wrong
Hey, my mp3 player turns on but once it does it won't turn off. It will display the RAVE MP logo on the screen when it turns on and usually after a few seconds the logo will flash and it will display the main menu. The problem is, when I turn it on it'll show the logo, the logo will flash, but then it turns off by itself and makes this click sound and turns back on again and shows the logo, logo flashes and it does it again and again until it's plugged into a USB or it runs out of battery. Then if I go to charge it up, it'll turn on and do the same thing over and over again! I can't listen to my music on it, but my computer still will read it and I can still play songs on it that way, but when I disconnect the USB it does the same thing again! I've tried everything please help me!
  • SamusV2 Oct 16, 2007
    Crap, I accidentally severed the battery's connection to the player, now it won't turn back on at all, I might be able to solder it back in and I'll see if that works, btw thanks! P.S. the player still works on the PC and it hasn't lost any data :)
  • 709 Answers
Hi Samusv2,
Try removing the battery completely for about 1 minute, then put it back in then try to see if doe shte same thing. Insert another comment on this post and I will respond.  Cross your fingers.
Posted on Oct 13, 2007
  • Greg Stokes
    Greg Stokes Oct 16, 2007
    HI samusV2,
    new clue,  sounds like contamination on the circuit card.. I am sorry that happened to you about the battery connector.  Good luck on the solder job.  If you go to like Radio Shack and get a circuit board cleaner with Brush, you should take your Rave mp apart, which you probably need to do anyway to solder the battery connector back on, Clean the board real good with the cleaner.  Something is resetting the player and it is in a loop.  This could be in the keypad circuit. Clean the contacts that the keys are pressing against real good too.
Computers not seeing the Rave MP3 player
Sounds Like you need to get device drivers for this MP3 Player. Try driversguide.com or drivershq.com. Hope this helps
Nov 19, 2010 | GoVideo Rave-MP ARC2.5 (2.5 GB) MP3 Player
How do I delete songs existing on Rave.mp ?
Once you can connect the device to your computer, it should popup like a use device that you can delete the songs or file you want.
Aug 17, 2009 | GoVideo Rave-MP AMP128 (128 MB) MP3 Player
Rave mp
This means that your unit is defective and is no longer working. The hard drive is bad.
I have bought 3 of these players. All of them worked for a while then had the eventual face/bug on the screen after turning the unit on. When the customer service number DID work, they said that the unit was defective and to return it to the store and get another.
This happened to me, like I mentioned, with 3 different units.
Aug 10, 2008 | GoVideo Rave-MP ARC5.0 MP3 Player
Windows xp wont recognize usb connection from rave. Is there a driver I need?
If you're using the retractable usb cable that came with the player, replace it. I had the same problem. XP recognized that there was a device, but couldn't open it. I was getting a "Driver not installed" error in device manager.
Jun 08, 2008 | GoVideo Rave-MP AMP512 MP3 Player
Coby MP-C827
It's probably just the mp3 player's malfunctioning on you...something must have happened during shipping and handling to the store you got it from.
May 27, 2008 | Coby MP-C883 MP3 Player
Rave-MP AMP126 MP3
This slot is for an SD card. You use this to expand the amount of music you
can hold.
Mar 24, 2008 | GoVideo Rave-MP AMP512 MP3 Player
Rave-MP 5.0
There are 2 issues- 1 the keys are locked - unlock and turn machine off. the other option is to recharge the battery
Jan 26, 2007 | GoVideo Rave-MP ARC5.0 MP3 Player
Rave mp mp3 player ---- frozen
Try a separate SD memory card (no bigger than 512mb). Also try replacing the battery if you haven't already. Mine has done this intermittantly since it was about a year old.
Jun 28, 2006 | GoVideo Rave-MP AMP512 MP3 Player
GoVideo Rave-MP ARC5.0 MP3 Player Logo
108 people viewed this question
Top GoVideo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a GoVideo Audio Player and Recorder Expert? Answer questions, earn points and help others
