Question about GE ZDW24A Wine Cooler
Thermosthat doesn't work
Dial thermosthat up unit clicks on and will not shut off. Dial thermosthat down till unit clicks off, it will not come back on. How difficult is it to change this part ? How much should the part cost ?
    Scholar:
  • 152 Answers
Hi , yes it sounds like the thermostat is stuffed.  To replace it is relatively simple but always keep in mind , switch off and un-plug it before working on it for safety ,  to replace it you will need a phillips head screw driver , a flat screw driver and a note pad,  where the dial is , that is the thermostat , the surrounding screws are what hold it in position so removal is only a matter of having a real good look inside . Thermostats for this purpose are about $15 to $35 dollars depending on your country . replacement time is about a hour depending on how much trouble to have getting the old one out. remember that this device has a small alloy tube which is the sensing part of the thermostat , be careful not to damage this because it carries a small refrigerant charge which is the primary temperature sensor so please be very careful and above all take your time .
I hope this helps you ,
Thank you and have a nice day:)
Posted on May 12, 2009
  • Paul G
    Paul G May 12, 2009
H1 Fault ?
heat sensor. thermosthat bad.
May 21, 2016 | Heating & Cooling
If i forgot to put wire on thermosthat will that cause radiator to blow
NO The wire was probably for the temperature sender unit and the gauge would read nothing if it was lose of overheat if it was touching metal. radiators blow from excessive pressures generated from over heat or faulty head gaskets. have a compression test done to check for blown head gaskets or cracked head/s. The radiator will crack if there is excessively low ambient temperature ( freezing) and the antifreeze is below the correct concentration
Dec 24, 2013 | 1994 Chevrolet S-10 Blazer
Dometicthermosthat #3313192.000
Ring DS supplies on 01782-625551 Ask for chell
Aug 16, 2012 | Refrigerators
Dash lights dont work on 2000 mitsubishe eclipse
change out the water pump that should solve your problem for over heating.
Mar 17, 2010 | 2000 Mitsubishi Eclipse
This car is overheating i ready change the thermosthat waterpump radiator hoses are good can you gime some idea what can be the problem
you need to pressure test the cooling system. to make sure nothing damaged inside. an internal water leak means you have a cracked head or block
Apr 08, 2009 | 1996 Ford Thunderbird LX
Thermosthat
Follow the top radiator hose to the engine it will lead to a housing that is bolted on the block the thermostat is inside that housing case You will need to remove the case take out the thermostat clean the old gasket awy from the block and housing case before you replace the new thermostat and gasket its always a good idea to put a light coating of silicone sealer around the housing where it fits together before you put it back on
Nov 07, 2008 | 2005 Ford Focus
GE ZDW24A Wine Cooler Logo
264 people viewed this question
Top GE Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a GE Furniture Expert? Answer questions, earn points and help others
