Question about Comet GXD2527G Pressure Washer Pump
Oil for Comet pump
Can I use over the counter pressure water pump oil such as sold by NAPA or is the comet oil the only product that should be used? Comet pump AXD 2524
  • 122 Answers
Aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
Posted on May 12, 2009
Y a t'il un niveau d'huile dans la comet bxd 2525
L'utiliser cette pompe sans huile est une erreur fatale:
[PDF]COMET PLUNGER PUMP SERVICE MANUAL INDEX
www.cometpump.com/_images/support/Pump_Repair_Manual.pdfLUBRICATION: Make sure crankcase is filled with Comet Pump oil. Running this pump without oil will cause damage and void any warranties. Change the pump ..
Mar 14, 2014 | Comet BXD 2525 G Pressure Washer Pump
Oil seeping from Comet BXD 2525 pump
out the drain plug ? Sight glass window ? Under the pump where the crankcase meets the pump head?
tighten plug, replace oring on sight glass or replace low pressure seals if near the pump
Dec 09, 2013 | Comet BXD 2525 G Pressure Washer Pump
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
Comet tw 5050 mix oil and water
what you have is a bad seal or a crack within the pump crack more common if any water was left in it during the cold winter
Jun 22, 2012 | Comet Pressure Washer Tw5050 Triplex Pump...
Oil coming out of oil fill plug on my AXD2524 pressure washer
I think install right angle elbow then short tube upwards,install the breather to this.
Sep 19, 2011 | Comet AXD2524G-T Pressure Washer Pump...
Oil and water comming out of oil filler stem
You have a seal on the pump between the pump and the water pump thats leaking you have oil and water mixing . I owen three mechines and i don't understand what you mean when you say the oil filler stem. I also rebuild power washers and pumps. If you can clarify where the water and oil mixture is comeing out then i can tell you excatly what the leak is thanks
Jan 09, 2011 | Comet BXD2527 Pressure Washer Pump
What type of oil goes in a comet axd 3020 pressure washer pump?
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
Jul 14, 2010 | Comet GXD2527G Pressure Washer Pump
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
What kind of oil do I put in my Comet AXD2524G-T pump?
If the Comet Pressure Pump Oil is some kind of a
Synthetic Oil that supposed to be extra effecient than
an ordinary oil, then that will cost extra. If that is ordinary multi grade engine oil (SAE 20 - 40), then, you
can buy over the counter. Most synthetic oil have additive that give extra longer life to all moving parts.
Nov 27, 2009 | Plumbing
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
Comet GXD2527G Pressure Washer Pump Logo
2,288 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
