Question about Leapster Learning System
Leapster pen not working
Hi leapster pen doesn't work, tried new batteries, cleaned the pen, it still didn't work, do you have any suggestions or known solutions, do I need a new pen? Thank in advance, Greg
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on May 15, 2009
New batteries installed and leapster learned will not turn on. Is there any way to reset it? I even tried new/different batteries that are brand new. We have an 11 hour trip tomorrow!!! Ahhh...
With new batteries the leapster should of turned on. Take the batteries out and look on the contacts inside where the batteries would normally go. See if there any corrosion or anything sticking to the contacts. If it is then clean it with a rag and glass cleaner and then try new batteries again, if it doesn't work then you know the mainboard inside is bad. Also if nothing is on the contacts and you know for sure the batteries are new then the mainboard would still be the culprit. At that point you would have to buy a new leapster because there is no parts available for it. If its under warranty bring it back to the store where you got it so they can get you another one.
May 28, 2011 | Video Game Consoles & Games
I have leapster l-max and am having trouble with the stylus working. when i try to calibrate, i can't click on center targets
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
Feb 05, 2011 | LeapFrog LeapSter L-Max Console
Leapster 2 screen not working
Hi
This is a common problem for Leapster. The company has a repair program. Charges depend on warranty.
May 11, 2010 | Leapster Learning System
the screen maybe dirty try turing it off and cleaning it with a rag
Mar 18, 2010 | Leapster Learning System
Pen not working on screen to use
Hi, have you tried to recalibrate the screen as in your instructions?
Make sure you have no game inserted
Press and hold down the 'on' button and 'hint' button (with questionmark on it) at same time until a menu appears on screen
Press A
Now touch all the little crosses with your pen that appear on the screen
switch leapster off and restart
if still not working, repeat above
Jun 15, 2009 | LeapFrog Leapster 2 Learning System
Leapster pen or touch broken
leapster 2 comes on but when you touch screen with pin wont do anything
Apr 01, 2009 | Leapster Learning System
The pen won't work on my daughter's leapster
Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
Leapster with broken pen
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
Leapster screen not working
Apparantly, the Leapster screen issue is a common problem. While this suggestion is not ethical and since my game was near perfect condition, I went to Wal-Mart and bought a new one of the same color and then returned the broken one.
Jun 12, 2008 | LeapFrog Leapster Educational Game: Disney...
Leapfrog Leapster touch screen
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
Leapster Learning System Logo
2,047 people viewed this question
Top Leapster Toys Experts
thegtw
Michael Vincent Cruz
Dennis Crouse
Are you a Leapster Toy Expert? Answer questions, earn points and help others
