Question about Keurig B60 Coffee Maker
Water leaks out the bottom of my b70 keurig - Keurig B60 Coffee Maker
  • Anonymous Mar 25, 2014
    leaking water container keurig B70
  • Anonymous Mar 29, 2014
    Replace Keurig B70 water reservoir
  • Keurig Master
  • 1,711 Answers
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler . All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Posted on Sep 27, 2010
    Sniper:
  • 67 Answers
Save the trouble, either return it to where ever you bought it, Most likely Costco and get a nother one. If not i know of this great site that sell them for half of retail price and all kinds of replacement parts. http://stores.ilikenew.com
Posted on Nov 12, 2010
Keurig troubleshooting
Water pot part leaking from the rubber part on bottom? that's the only thing I could think for you to check. Maybe not getting a good enough connection to the coffee maker itself
Aug 06, 2014 | Keurig Platinum B70 Coffee Maker
My Keurig leaks from the bottom, it's a pain.
You may have water in the holder that supports the CUP. It needs to flushed as it has a limited area for maintain the overflow.
Mar 12, 2013 | Keurig Platinum B70 Coffee Maker
Keurig b70 water tank leaks out all over the counter
Shut-off valve failed, retry a second time and it will reset accordingly.
Dec 31, 2012 | Keurig Platinum B70 Coffee Maker
It is leaking water out of the vents on the bottom.
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Jul 09, 2011 | Keurig Platinum B70 Coffee Maker
Leaking from the bottom of my B70
heatman101
Jun 21, 2011 | Keurig B70 Coffee Maker
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Apr 23, 2010 | Keurig Platinum B70 Coffee Maker
The Water Reservoir is leaking on my keurig coffee maker.
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Mar 23, 2010 | Keurig B70 Coffee Maker
Keurig B60 Coffee Maker Logo
1,389 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
