Question about Garden
While cutting grass or not the rider will stop moving for a split second and start moving again.What's wrong?
  • 218 Answers
Im not sure what kind of mower you have..or what year it is..but in general..if you mash the clutch/brake in..and it barely stops..then the brake pads are probably worn out..and most riding lawn mowers brake pad is loacted on the right had side of the rear axle..it looks like a small disc brake..i hope this has helped..if not write me back...Keith
Posted on Jun 30, 2009
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
Check gas cap for proper venting, will it run better with cap off.
Feb 13, 2016 | Garden
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
After emptying the grass from the storage on the back of the rider, when I start to mow again, the grass that is in the catcher from the deck to where it shoots out, gets clogged and will not move on to...
Clean out your chute also and don't let the catcher get so filled up, check it for readiness to empty more often.Don't cut wet grass that tend to stick and cause trouble. Good Luck...709
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My rider stopped in high grass, would not start.
first must by the connection bettw.battery and starter.second mesure short cut of the starter .try cu see if you have the seal battery or not.in this case try to see if there is mixture water + acid(enough) on it.other solution -you have broken battery charger relly.
Sep 11, 2009 | Garden
Rider want start
does it have spark & fuel if it has fuel & no spark you possably sheared the flywheel key let me know thanks wade
Jul 04, 2009 | Garden
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Lawntractor does not move forward or backward
you might check the pulleys to see if shear pin has broken.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
