Question about Sony PlayStation Portable (PSP) Console
Button my x button is stuck i have to press it hard in oder for it to work i didn' spill any thing on it it just happened please help me
  • jay007 Jan 06, 2008
    my psp x button is completely stuck and it only works for a couple things
  • 709 Answers
Hi Stevenper,
Something has gotten the X button dirty even with not getting something spilled on it.  The PSP case needs to be opened and that is best left to someone with experience in the PSP.  I have torn apart and repaired about 10 PSP consoles in the last month.  I can repair your PSP for you for $28 including return shipping.  My Email is Repairtech@  I run the Playstation Clinic at
Posted on Oct 15, 2007
Stuck logo screen ipad
Probably frozen, you can try a hard reset. Just press both the power button (top-upper right) and home button (lower-front circle button) at the same time for about 10 seconds until it restarts. Post here again if this doesn't work, what was the last thing you did before this happened?
Oct 17, 2013 | Coby Kyros Internet Touchscreen Tablet...
Meep tablet won't start (frozen start up)
There are two things you can try for this. The first is to reboot the tablet using the power switch. The other is to press in the Reset button on the backside of the Meep. If neither of these helps the situation, you'll want to contact the OSI call center.
Feb 03, 2013 | Oregon Scientific MEEP Android Kids Tablet
My mac screen is in negative and it still doesnt change when i press control option command 8 (it just makes the screen lighter). the colors are off unless i press the dashboard button but its annoying...
Unfortunately with any kind of liquid damage all bets are off. You can change one thing and it may or may not fix the issue. And after some time you might have a completely different issue. You're smart thing is to cut your losses and get a new computer. Remember to backup your system before you lose everything. To be quite honest I'm surprised still working. Good luck.
Oct 19, 2010 | Apple iBook Mac Notebook
Karcher 211 - no motor action
Dear Tigger82 (also montaver2000),
This explaination is relavent to various Karcher models, especialy your model. When you are using the machine with the gun open....presurised water comes out of the lance. When you close the gun, the machine stops. This happens by means of a Spill Valve or often called the Control Valve. When the gun is closed, this spill valve cotracts with built up pressure and at the same time works on a miro switch which cuts the electricity....and thus stops the electric motor. Now in many cases when the gun is again opened, this spill valve sticks and keeps the electric circuit closed.
In all cases you must open the cover, and locate this spill valve. Sometimes it is easy to see a micro switch on it. If you remove the miro switch from the spill valve the motor will for sure turn.
Now the spill valve gets stuck for many reasons. One of the reasons is that you leave the machine under pressure for a long time and even store away the machine with pressure still in the system. A spill valve also gets stuck due to detergent. I sometimes service the spill valve and lubricate with special solicon grease. But the best way is to change the spill valve with a new one. So in a few words, the spill valve is stuck and leaving the microswitch off. So the electric motor cannot turn. One final hint is that sometimes the spill valve is difficult to remove. So all one has to do is attach water supply and switch on the pump. With the pressure produced the spill valve will be pushed out. In my oponion this job must be done by a person who knows what he is doing. Carefull that you have safety electrical breakers. See that you have safety shoes, safety gloves and eye protection.
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
I have a Dell studio and a cd is stuck in it. I push the eject button & nothing happens, there is no hole anywhere near that button. I've tried a few things but it's still stuck.
turn off the pc. when you turn it back on immediatly press the eject button. i hope this helps.
please remember to rate me.
best of luck
Mar 06, 2009 | Gateway MT3705 Notebook
Menu keeps popping up; Stuck buttons perhaps?
Yes, a stuck key would be a likely culprit. Sometimes a key will get stuck out of just plain useage/wear, or, pop or other liquid spill or splatter will result in a sticky key. Press on the suspect key-compare to another key- different feel will tell you a problem exists.
Low cost keyboards don't generally have the life expectancy as older higher quality ones. Laptop keyboards are also more fragile, and subject to problems.
Dec 23, 2008 | Dell E153FP 15" LCD Monitor
Nothing happens when I press the power button except the light
Regardless if you don'r feel comfortable taking the comouter apart it needs to be taken apart and looked at. Depending on what got spilled inside the sooner the better. If it was a soda of some kind it could be bad.I would take out the battery and not try it again.
Oct 03, 2008 | IBM ThinkPad T60 Notebook
Button Problems
happened to me be4, except all my buttons didn' t work. I just did what people do in movies. throw it aroun, step on it, bang it against walls, desks , ect. Then my teacher took it away. The banging cleared all my ram. It was weird, but it started working.
I think the circuit board moved, and i hit it back into alignment.
May 19, 2008 | Texas Instruments TI-84 Plus Calculator
My eject button
Literally give Nintendo a call 1-800-255-3700. They might offer you a replacement console.
May 05, 2008 | Nintendo Wii Console
Sony PlayStation Portable (PSP) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
