Question about MSI Wind U100-030US Laptop
How can i use my webcam? i cant find it to my computer or devices manager
How can i use my built-in webcam? how can i use it?? msi u100series notebook
BUILT IN CAMERA NOT FUNCTION
What Software are you trying to use with the webcam? Open Device Manager, Imaging Devices, is the webcam there? Is it enabled? If you need a webcam driver try here: http://www.msi.com/service/download/
Dec 13, 2012 | MSI Notebook FX420001US 14inch Core...
I used my webcam once and now it shows only a black screen what can i do its an MSI U135
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver xp
click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
software if you dont have the driver you will need to download one here are a few you could try although i could not find one for windows 7
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
hope this helps
Aug 22, 2012 | MSI Wind U135-644US Black Intel Atom...
How to fix msi u135dx webcam?
If it is an internal webcam (the one on the top of the monitor) look for a key on your keyboard,which has a webcam picture on it,then press the key and Fn (function) key at the same time when you're on the desktop
If it is an external webcam (which connected to the USB ports) go to Device Manager by right clicking on My Computer,select Properties,on the Properties window click on Hardware tab,then click Device Manager. Or if you are using windows Vista or windows 7,you can type "device" on the start menu and select Device Manager
On device manager window,expand the Universal Serial Bus controllers and see if there are an USB which has "?" sign on it (or any sign)
Then right click on the signed device (if there are one) and select uninstall,follow the uninstall process and restart your computer
The computer will reinstall the driver automatically
Please let me know if it's working
Jul 24, 2012 | MSI "MS-U135DX-1679ZA 10"" Netbook, 10""...
Have msi u 100 plus and had built in webcam...?now,all of a sudden the cam is gone it says cant detect cam?
Yes. MSI U100 Plus had built in camera, and this device uses the native driver bundled in operating system. There are two possibilities can cause this, problem with camera itself or problem with your operating system...
Aug 06, 2011 | MSI Wind U100-016US Laptop
My built in web cam not working what should i do?
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver hope this helps
May 11, 2011 | MSI Computers & Internet
I installed everything i needed to but my computer won't find my camera,it can't detect it when i run MSI My Guard Life...Can someone help me?
Hi. First check if it is detected in device manager. If it's recognized in device manager maybe it is used by other program like Skype or Messenger, so try to exit all programs that may use webcam and than run MSI My Guard Life. If it is not detected in Device Manager do reinstall the drivers. First uninstall all you've installed, than unplug your webcam, install driver and software and then plug it again. . Hope it will help you. By the way if you don't know how to get to Device Manager look here .
Good luck! Feel free to ask more questions if you need.
Feb 02, 2011 | MSI Starcam 370i Webcam
I cant find the webcam
here you go My Computer -> Manage -> Device Manager -> Imaging Devices
if you find webcam driver, then you webcam is ready to use
Dec 29, 2010 | ASUS Systems K50IJXD1B Notebook
MSI wind U100 built in webcam
Try to press FN key together with F6 to makes the webcam works
Mar 27, 2009 | MSI Wind UmNotebook
How to activate the builtin web camera on my MSI laptop
Press the blue "Fn" button on the lower left hand side. Then as your holding that button down...press "F6". There should be a small webcam icon on this button. This worked for me so I hope this helped!
Mar 19, 2009 | MSI M670 Notebook
MSI Wind U100-030US Laptop Logo
247 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
