Verbatim 250GB portable harddrive is not working on my computer
''My Computer'' on my desktop pick up this harddrive as a removeable disk, but, trying to access the disk, I get the message ''Please insert a disk into drive D:'' The drive does work on my laptop. I have Windows XP.
  • Anonymous May 13, 2009
    Nothing pops up.
    Problem Solver:
  • 16 Answers
Look at what pops up in your my computer window when you connect it to your computer
Posted on May 12, 2009
Verbatim clon harddrive 250 gb wont show up
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems"
hope this helps
Jul 12, 2011 | Verbatim CLON Portable, 250GB, USB,...
I can't locate the drive on my computer? I have a verbatim usb 250
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 26, 2010 | Verbatim SmartDisk Firelite Portable USB...
My pc doesnt recognitze my portable verbatim hard drive anymore, model 47512, and their support page sucks. what can i do?
First, try to connect it to a different computer, to see if it can be read on _any_ computer at all.
Second, check the warranty-status of the unit; if the warranty still is valid, Verbatim will replace the hardware (but will NOT make any attempts to 'recover' your files).
Third, an external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem.
Aug 20, 2010 | Verbatim External, USB 2.0, 750GB...
I am format my hard disk{verbatim 250gb model #47562)now he not support with my dvd player. there showing file not available. so i need softwear
it is not a sofware problem... if the disk was recognized before.
try reformatting the disk and select fat32 as file system. do not chose quick format.
try again to connect to dvd player.
regards,
paolo.
May 21, 2010 | Verbatim SmartDisk Firelite Portable USB...
I bought a Verbatim Clon USB Portable HardDrive to back up files from my Mac Computer. When I click and drag, I get this pop up " items can't be move because verbatim can't be modified." It says the hard...
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Dec 19, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I can´t see the portable hard drive unit in my pc
I don't know too much but I may be able to help. I started by closing all applications and then plugged the USB into the port. A few moments later a window opened and when I right clicked it allowed me to make a shortcut to the desktop. The Verbatim icon is now on the desktop and I can click it and it opens. I have Windows Vista and can also open the "computer" option and the hard drive is there - mine shows as drive "f". I hope this helps. I am a good user of the computer but a novice at installing, un-installing, etc.
Nov 22, 2008 | Verbatim SmartDisk Firelite Portable USB...
Verbatim 250GB External Hard Disk not recognized by PC
Almost always, when a USB drive doesn't assign a drive letter in MY Computer the issue is a Mapped network drive using the drive letter the USB drive is attempting to use.
With the drive connected, open DISK MANAGEMENT find the USB Drive, right click it and assign it an available drive letter.
Jun 12, 2008 | Computers & Internet
Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Jan 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
