Question about ASUS K8V SE DELUXE, W/SATA,RAID,LAN(Gb),USB 2.0&AUDIO (Athlon 64 - SOCKET 754) (MBASK8V) Motherboard
BIOS reports does
New Build. ASUS K8V-X SE, Sempron 3000, 2GB PC32000 Ram, ... I turn on the power and it comes up with the BIOS screen and then says ""TAB" to User window" then it says "BIOS does not setup press "g". then it cycles back to BIOS screen. I might add the same thing happens with another MB (Gigabyte K8VT800 Pro)and the memory is recognized in BIOS setup on both boards. I also tried using a HDD that already had an OS on it and it still won'tboot into windows and I get the BSOD. Please Help!!!
  • Victor Novak Aug 19, 2009
    No it is not the latest BIOS. I have downloaded the updates but can't figure out how to install them since the only other PC I havve is a Laptop w/o a floppy drive. I tired creating a Boot CD but the system won't recognize the DVD drive after it boots. So I am unabled toupdate the BIOS.
    By RTC, do you mean the Real Time Clock? If so I tried resetting (more then once)and it didn't work...
  • Dan Todd May 11, 2010
    You cannot use a hard drive with windows on it unless it has been installed in the computer you're using.
    A lot of Asus boards have that message on them, not sure why. I have 4 builds on Asus boards. I also have similar problems when I try to use OCZ ram. But I never press "g", and they go on and boot up. Some of them say "no harddrive recognized" but boot anyway.
    Do you have the latest bios? At this point, I would reset the RTC if I were you, and try again.
Asus k8v-mx bios problem
This is the result of a bad flash. There is nothing that you can do unless you reflash the bios to another version. In some cases you have to order a new bios
Aug 03, 2017 | ASUS K8V-X SE Motherboard
Can i fit a bigger processor to my ASUS K8V-MX Motherboard and mybe more ram and if so where can i purchase it from
This motherboard supports a AMD Athlon 64 / Sempron processor (Socket 754). Since this is an older unit you will have to search on Ebay for a processor.
As for the RAM you will need DDR 400, this can easily be purchased at www.newegg.com There is a maximum of 2 gb on your motherboard.
Mar 17, 2011 | ASUS K8V-MX Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Asus k8v-vm wont resume from standby.
get into the bios and change the setting to start from any key save yes and ok -esc
Jul 04, 2017 | ASUS K8V-VM Motherboard
Asus K8V SE Deluxe - will not turn on
it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Dec 05, 2008 | ASUS K8V-MX Motherboard
AGP installation problems
If you do see the BIOS post but the screen turns black when your OS is loading, then the AGP-card should be OK. HOWEVER, you do need to uninstall your MB-video drivers before installing a new GPU.
Jul 06, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
75 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
