Question about Nikon COOLPIX S6 Digital Camera
Black LCD Screen.
I cant take any pictures because they all come out black.  The screen is completely black when you have it in camera mode.  But i am able to view the pictures perfectly fine. What is wrong? And is it a defective problem or something that i did to the camera?
  • pumkincakez Oct 21, 2007
    im really not sure where exactly ur hittin ur elbow on?? and what does beating it have to do with it? lol was it just a coincidence for u?
    Scholar:
  • 32 Answers
If you want to follow my way to try fixing it yourself, keep reading and do it at your own risk. You paid several hundread dollars for the camera and I just paid $20 for it. Therefore, I tried everything I can to make it work, even if I had to open the camera body to play with the inside. Fortunately, it was not neccessary to take it apart.
Once again, AT YOUR OWN RISK to follow my way to get back your real time image screen.
Read the following steps once and make sure you understand before action.
(1) Load your camera with a freashly recharged battery.
(2) Switch on to see if it's working and still without the real time screen.
(3) Switch it off, and hold it tight in you palm with the LCD facing inward.
(4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash.
(5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear.
(6) Match the aim as describe in(4) to the aim of your elbow 's protruded part and make pratice moves. Yes, you'are going to smack it
to your elbow.
(7) When you are ready, try first not to hit your elbow too hard once.
(8) Switch the camera on to check. If you have the 'Screen' now, congratulation! If not, repeat (4) to (8) but with a stronger impact
Force. You might have to try more times until your elbow could not take the sore.
I got mine fixed by performing the above steps just once, but I started at a medium impact force. Before this fix, I tried to whack it on both sides, the top and the bottom to my knee cap.
Why I chose knee cap and elbow? They hurt if you strike too hard. The target is to apply enough impact force to shake but not break the parts inside the camera.
Good Luck!!
Posted on Oct 21, 2007
  • walkietalkie
    walkietalkie Oct 22, 2007
    Read point 4, that is the aim of the camera to be hit.
    Read the last 2 lines, that's the reason why to hit.
    Something is out of place inside, this impact force is to shake it back to normal.
    If you need to hear successful stories, click here to read 'Answers' dated after September, 2007.
THIS SERIOUSLY WORKED. I just tried smacking it against my elbow for about 40 minutes, and finally i just smacked it against a shelf, and my camera is BACK!!! I am SO happy. Thanks!!!!
Posted on May 09, 2008
    Problem Solver:
  • 19 Answers
This solution works, although i just smacked it against a window frame after my elbow started hurting. small dent, but worth it.
Posted on Apr 09, 2008
I confirm again, it's worked. after check cost service 80 us dollars, I can not accept cost. just try smack medium power with your elbow as above.
thanks so much, good luck.
evilas
Posted on Mar 21, 2008
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Cant take photos with my Kodak ZD710
check eye settting or its a fungus inside lens black screen is due to virus
Jun 18, 2009 | Kodak ZD710 Digital Camera
Black LCD screen/ not 'seeing' picture. Canon EOS 400D camera
Hi
The Digital Rebel XTi doesn't have 'live view' mode, you can't see what you're taking a picture of before you take the picture.
Thomas
Darntoothysam com - Digital camera parts and repair.
Nov 11, 2008 | Canon Rebel XTi / EOS 400D (body only)...
THE LCD SCREEN IS BLACK AND I CANT TAKE A PICTURE. BUT I CAN STILL VIEW MY PICS. THE CAMERA GOES THRU ALL THE MOTIONS LIKE IT IS TAKING A PICTURE BUT IT IS JUST COMING UP BLACK.
The LCD screen is black and I can't tace picture. But I can still view my pics. The camera goes thru all the motions like it is taking a picture but it is just coming up black.
Aug 31, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Pictures are black
If you can display pictures in playback mode but screen is black in capture mode then the CCD sensor has stopped working and needs replacing.
Sep 12, 2007 | Kodak EasyShare LS443 Digital Camera
Panasonic digital camera has black screen
CCD sensor faulty especially if you can play back pictures that were captured properly, but have a blank screen in capture mode. Replace sensor and camera will work fine.
Sep 12, 2007 | Panasonic Lumix DMC-LZ1 Digital Camera
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Sep 05, 2006 | Konica Minolta DiMAGE A1 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Dark LCD
Is it possible that you've gone into M (manual) mode and the shutter speed is fast and a small aperture (large number) been selected? Or has the Exposure compensation been adjusted to be -2? Does it do the same thing in fully automatic mode? It certainly sounds like some setting has been adjusted incorrectly.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Nikon COOLPIX S6 Digital Camera Logo
181 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
