Need to replace rusted top on washer. Have top, just can't figure out how to get to the screws holding it on. Have schematic. Will transfer existing lid and switch to new top. Thanks
  • tdrathompson May 13, 2009
    Figured it out. Remove the console, mark and unplug all wires and the water level tube. Remove the three screws on the bottom of the back panel, and release the plastic tab near the bottom. This frees the back panel which will tilt back. The entire top and three sides are loose now. Pick it up off of the metal tabs on the bottom frame. Flip it over and remove the top, and reverse for installation.
  • 181 Answers
Some have 2 or 3 screws on back when released push lid forward or backwards, others are more tricky the front panel has to be removed this can be snap connectors or hidden screws under the panel .
Posted on May 13, 2009
The lid to my whirlpool cabrio top loading washing machine will not open completely???
Hello. How old is your washer? Is there rust around the bleach dispenser near the left side hinge? What probably has happened is the hinge assembly underneath the top cover has rusted from the contact with chlorine and or fumes. These washers are notorious for rusting at the hinges, especially near the bleach dispenser. The parts involved are:
left hinge arm--w10389421
right hinge arm--w10389240
left hinge spring assembly--w10358931
right hinge spring assembly--w10358932
top cover--w10391067--if this needs to be replaced, call for service--it's a solid hour to 90 minute job for an experienced tech! You have to transfer ALL THE PARTS to the new cover and it's INVOLVED--trust me! If there is rust around the bleach dispenser and underneath the top cover, you might check your serial number with Whirlpool to see if you can get a new top cover for free covered by a service bulletin dealing with rusting. To raise the top cover, remove the top screws from the hinges on the rear of the washer holding down the top cover. Then, remove the screw and metal plate protecting the wire harness and pressure hose and set it aside. Next, from the front, slide the top cover forward 1/2 inch and lift up. Have a friend assist you in holding up the top cover. You can now access the hinges mounted underneath, check for rust, and also see how the suspension rods are mounted(they are very easy to remove since there is a slot in each rod holder located at each corner at the side of the tub near the bottom. You would pull up on the tub, release the top of the rods first, then reach down and unsnap the plastic clips(2) in the center of each holder. Use a headlamp or flashlight to see. The rod will drop down and can be removed through the slot. Reverse the procedure to install.
Also, in case your suspension rods get worn out(the tub has a hobby horse "bouncy" movement), the part number for the set of 4 is w10368625. The proper way to check the rods is to place your hands on the right and left side of the tub ring(the plastic cover over the basket) and shove smartly down and release--the tub should grip going down and pull coming up--no springy movement--just like shock absorbers on a car. It should come up and settle. If it has any bounce at all, the rods are worn--symptoms will be increased out of balance errors or the washer might start banging during spin. I hope this helps you. If you are hesitant about performing any of the repairs above, please call for service!
Oct 03, 2015 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Freeze proof faucet dripping badly (hardly used, 6 yr old), bolt holding plastic handle seems pretty well rusted on. I'm trying toi figure out if there is a servicable washer that needs replacement.
It does have a serviceable washer. Use a 12" crescent wrench on the collar. unscrew the head and pull out. You may ALSO need to unscrew or "open" up the faucet to unscrew the threading in order to put the shaft out of the body. The spray and work the rust off with WD40.
Mar 20, 2010 | Plumbing
Something caught between drums
I will try to explain open the door remove the screws that hold the door on lift up on the door it should come off now remove the other two screws on the other side of the door two white clips should come off now grab the top of the front panel and pull it out now you will see insides remove 2 screws that hold the clip that hold the lid down make sure you undo the screws in the dispencer before lifting the lid goood luck
Mar 29, 2009 | Maytag MAH6500 Neptune Front Loading...
Lid switch is broke and need to replace.
1. Unplug machine
2. Remove two screws in back of angled top part connecting it to base, lift back up 4-6" and shift top toward front 1/2" so tabs holding front of top to machine base can disconnect.
Mar 27, 2009 | Kenmore 24622 Top Load Washer
Need to remove the drive coupling on a kenmore 80 series washer
Remove the two screws holding the motor bracket braces, pop off brackets, pull it out.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
How do you remove the top of a MAH5500B Front Load Washer
you need to remove the door hinges and the screws opposite the hinges. that will allow you to remove the front panel and the you will see the latch and the top hold down screws. once you have the top up, then you will also need to remove 2 screws that hold the latch to the upper frame. it is hard to pivot the latch out from the frame but it will come out and then you can replace the assembly.
by the way.. why are you wanting to replace the latch?? any failure codes? you might also have to replace the control board as it will fail when the door latch shorts out.
if you look at the control board you might see some of the resistors that have burnt out/ shorted out. sorry but it happens alot.
if it is less then 5 years old, then you might get it fixed under warranty for free part.
Jan 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite washer lid removal?
how do i remove the washing machine the top
Oct 20, 2008 | Washing Machines
Need schematic to remove top
No schematic needed.
Unplug washer
on the bottom of the control panel remove two screws, one on each side.
control panel flips up and over self.
Now on each side under control panel are gold colored clips to remove cabinet from back panel. use a screw driver and release clips,
unplug any wires going to top panel from rear panel that make hold back cabinet,
Cabinet pivots on locator pins on lower front of base. Now with cabinet removed, top can be removed from cabinet shell
Jul 15, 2008 | Whirlpool Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
