Question about Freezers
Freezer keeps freezing solid
My Maytag M2360W is considered by Maytag to be obsolete. The freezer keeps freezing solid so the fridge stops working. I guess its a thermostat problem but not available from Maytag. HELP!
    Scholar:
  • 152 Answers
Hi , yes it could be the thermostat but more likely the defrost timer , most parts are replaceable with generic ones , your local refrigeration supplier may be able to assist you with the right selection simply by giving him the model and brand , these parts will not cost more than $100 bucks . if you are competent in checking please follow this simple test.
first turn  off the fridge and get to the back of it , remove the covers and get a good torch to see underneath where the compressor and other components are , now there should be a black object (compressor) with two pipes coming out of it (if there are to small pipes coming out of the bottom and they run back into a tray on top or next to the compressor they are not the ones ) now turn the fridge back on and wait about 15 minutes feel these two pipes , one should be sort of luke warm and the other should be warm to hot , if this is not the case then the refrigerant has leaked and a tech will need to be called if they are, then the defrost timer is faulty in which case it will be located under the fridge and have a white button perturbing through the back wall down near the compressor , once you find this try turn it a full 360 Deg , if the compressor turns off while this is happening thats ok , keep turning it until it tries to turn on again but wait about five minutes before you turn it again to allow the pressure to settle , if the compressor does not shut down then the defrost timer is definitely shot,
I hope this information helps you.
Have a nice day :)
Posted on May 12, 2009
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Fridge working fine but freezer keeps freezing rock solid in a matter of weeks
check door seal fit tightly.if its frost free make sure drain is clear at the bottom of evaporater if all ok check defrost heater and sensors..
Sep 28, 2009 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
95 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
