Question about Epson Aculaser C1100 Printer
Not printing down right-hand side
Epsom C1100 - have put in new Cyan cartridge and new photo conductor two weeks ago. Worked fine until recently.
Regards
Sheila
Cleaned the Photo cell
Posted on May 13, 2009
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
No cyan on one side
maybe its out of ink or clogged
Oct 26, 2009 | Epson Aculaser C1100 Printer
Canon Pixma iP4600 not printing cyan
I had the same problem and I finally FIXED IT. I first tried replacing cartridges - no good, I then took the print head out, dismantled it and washed every component, no good. I then noticed that there were small streaks of blue on the paper when I tried to print a blue image so I worked out that the blue ink is getting through, but very slowly (yours might not be getting through at all but don?t worry this should still fix it). So I got a very thin pin and pushed it into the cyan pad on the print head creating a thin channel for the ink. Tried to print again, perfect, blue now working. Hope this helps - remember, you do this AT YOUR OWN RISK, there is no guarantee this will work for you, it worked for me but there is the obvious risks that you may break your printer. I did it because it was broken as far as I was concerned and I had nothing to lose if it broke completely, you must make that choice yoursel
Aug 25, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Horrible ink issues..
Unless you are printing a lot in that color, my Epson Stylus photo color R300 uses black at about twice the rate as the color ones. Most packages or ink, I find, also come with two black and one of every color. All my color ones seem to emply at approximately the same time as the others.
Mar 08, 2009 | Epson Stylus CX9400 Photo Printer
Cyan toner problem
Is the section that is not printing down the r/h side of the page?
If so then it is likely that one of your toners is not "locked" in fully. Open the top panel, lift up the orange lever and pull out the PCU. You can now rotate the cartridges, check each one is fully locked in by the coloured levers on the r/h side. Even if one is slightly raised it will block the path of the laser and cause the symptoms that you describe.
Please take a moment to rate this solution. Thanks.
Mar 07, 2009 | Epson Aculaser C1100 Printer
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Changing toner cartridges
Go to reset menu on printer LCD Panel
Hit enter button
Scroll down until you get to the "Change Toner M/C/Y/K" hitting the enter key when you get the appropriate letter.
This will rotate the appropriate cartridge to the opening!
Dec 19, 2007 | Epson Aculaser C1100 Printer
Print quality Epson C1100
It sounds as though a cartridge is faulty. To determine which one, the easiest way is to run a page of text/block of colour through in yellow then cyan then magenta. which ever page comes out with the streaks on it will tell you which cartyridge to ditch and replace. Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Epson Aculaser C1100 Printer
Cyan cartridge
My IP4200 started doing this about a week ago it tells me I have two Cyan cartridges. I don't, cartridges are canon cartridges and were changed four months ago worked fine until now. Pressing the middle button the resume button is working eventually, so far, but I don't know for how long. Seems like a hardware problem as I deleted and reinstalled the software no difference and everything worked fine for the first four months.
Jan 11, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Aculaser C1100 Printer Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
