Question about Acer Aspire One Netbook 8.9" Notebook
Media test failure, No bootable device, insert boot disk.
There is no place to insert a disk.
    Problem Solver:
  • 13 Answers
That happened to me when I tried to upgrade. If you don't have an external DVD drive, you have to copy the restore disk to a flash drive, put it in the USB drive, power up, hit F12 at the first screen, move the highlight to the USB and boot from it.  Oh, and it has to be at least    1 GIG, the USB Flash drive does, or it won't fit.
Posted on May 18, 2009
  • Acer Master
  • 32,281 Answers
Media test failure, no bootable device error message means the hard disk has failed, therefore cannot boot up.
If reseating the hard drive doesn't fix your problem then replace the faulty drive and install Windows on the new drive to get the computer operational again.
Posted on May 12, 2009
4 Suggested Answers
zabolyx
  • 38 Answers
SOURCE: comp won't boot
This could also happen if the hard drive is dead and trying to boot the next item or the BIOS has the Netboot option set as the first boot device.
Jump into your BIOS and make sure that the boot order is CDROM then USB then HDD. Then try again. Let us know what happens.
Posted on Apr 02, 2009
parrotheadpc
  • 2600 Answers
SOURCE: no bootable device message, says insert boot disk what is that
Usually this is idicative of a hard drive failure, try to boot with the windows cd and see if it will boot up. Try this below......
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Nov 21, 2009
Keynan
  • 977 Answers
SOURCE: PXE-E61 : Media test failure
It sounds like your hard disk has gone, or not being recognized by the computer... Check if it seats well in it's place.
Unfortunately, laptop HDDs don't last long these days.
Posted on Oct 18, 2010
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
My laptop is not booting, It is written as "No Bootable device- Insert boot disk and press any key"
go to bios and set hard drive to number 1 and cd/dvd rom to 2 in boot menu
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Sep 24, 2015 | Computers & Internet
When i turn on my computer it says PXE-E61 media test failure, check cables. then it says no bootable device- insert boot disk and press any key
Check your BIOS and ensure the proper boot device is selected and enabled.(Look for the default boot device. Select the primary hard drive and save.)
Apr 10, 2015 | Gateway NE56R10u Laptop Intel Celeron...
Well, my computer doesn't start up and the screen says "Media test failure, check cable", "No bootable device -- insert boot disk and press any key". I don't know what the cable is and...
The uProcessor can't find a bootable device and presumes your hard drive is no longer plugged in. Standard error message.
Check your BIOS for the hard drive listing. If it is listed there is no problem with the cables.
You will need your restore disc to boot from and repair your boot sector on the drive.
Feb 21, 2011 | Acer Computers & Internet
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
When trying to reboot I'm getting this pxe-e61: media failure
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
PXE-E61 : Media test failure , check cable PXE-MOF: Exiting PXE ROM. No bootable device -- insert boot disk and press any key don't have a boot disk
Oct 18, 2010 | Acer eMachines 520-2890 Notebook
My Toshiba says PXE-E61:Media Test Failure, check cable PXE-MOF: Exiting PXE ROM. No bootable device--insert boot disk and press any key. How do I fix it?
check the boot sequence in bios
make sure that the first boot device is your HDD and disable the network boot
Sep 03, 2010 | Computers & Internet
Comp won't boot
Apr 02, 2009 | Acer Aspire 5315-2153 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
2,411 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
