Question about Canon EOS-1D Mark II Digital Camera
After one frame battery icon flashes ( battery is full charged)
Today I put a fully charged battery in my camera and shot one frame, when the battery icon began to flash and the camera would not take another frame.  Took out battery, put it back in again one frame and the battery icon flash.  Put in a different fully charged battery and the same thing happened with the second battery.  HELP
    Novelist:
  • 121 Answers
The problem is with the electric contacts between the battery and the camera. You can try cleaning them with a clean pencil eraser. Make sure you don't leave any eraser debris in the battery compartment. It is best to do this while holding the camera so that the battery compartment door is "down" so that any eraser debris will fall out of the door onto the table rather than fall into the compartment.
Posted on Dec 12, 2008
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
I have a Sony Cyber-shot Super Steady Shot DSC-T10. I have 2 babies under 2 years old and every time they are doing something adorable I can't get the shot because my delay on my camera is so long they are...
It seems the Red-eye reduction feature of the flash is ON. In this mode, the camera emits a pre-flash and then the actual flash discharges after a delay. Or it could be on Slow Sync. In this, the flash fires at the end of the exposure. Just go to Flash modes (the lightning-like icon) and if it is showing an eye-like icon or the word 'slow', change it to some other mode, probably the flash ON or OFF mode. Also, make sure that the batteries are fully charged.
If this solves the issue, please rate this solution.
Sep 02, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Camera does not turn on
It might be a battery issue: Please try the following: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 23, 2010 | Kodak EasyShare CX7525 Digital Camera
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Jan 12, 2009 | Fuji FinePix S7000 Digital Camera
Shutter button delay
The flash need to be fully charged before it would fire the shot.
In case the battery is old and supply power is not enough to boost the flash, it will await until the orange LED of flash indicator is no longer blinking, means ready to take picture with flash light.
Replace the new full battery will be better and faster to take shot with flash enable.
Jan 01, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Oct 05, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Low battery indication
You have either a faulty charger, a faulty battery or a fault in your camera. I purchased 2 batteries for my Sony 505v and from new one of them kept flashing an empty battery sign right in the middle of the display. Actually it was fully charged but Sony batteries have a little circuit inside them which tell you how long the batteries will last. In my case I could continue to use the battery but put up with that flashing icon. I returned it to where I purchased it and it was replaced Immediately. Please ,next time give us a little more information as to what battery type it is and which camera it goes in. Some cameras can develop a natural short circuit over time. BMW
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Fully charged battery last
Approximate number of recording images and playback times based on Minolta' s standard test condition* are as follows: *test condition: CIPA-compliant. (LCD monitor on, 1600x1200 size images, Normal image quality, Flash used with 50% of the frames) Recording Alkaline batteries : Approx. 80 frames Ni-MH batteries (2100mAh): Approx. 410 frames CR-V3 : Approx. 720 frames Playback Alkaline batteries : Approx. 275 min. Ni-MH batteries (2100mAh): Approx. 340 min. CR-V3 : Approx. 518 min.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Canon EOS-1D Mark II Digital Camera Logo
284 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
