Question about Dryers
DVLR223EE1WW - will not remain running after start button pushed. Would it be a door switch or relay?
    Problem Solver:
  • 11 Answers
I think elektro magnetic door switch.
Posted on May 12, 2009
I have a Sears Kenmore elite model# 11072942100 that will not always stay running when pushing the start button, however if I hold down the start button and then turn the dial it will eventually stay
Rick,
Good call on the timer switch. If the teeth have worn at the start position, starting would be delayed until the timer is rotated beyond the worn area. The normal operation of the start button is that it should to be pushed in and held for a second, to prevent inadvertent starts.The problem could be related to the door latch. The door safety switch will make intermittent contact if the door is not completely latched. If the door has become misaligned from downward pressure, it may not be drawing the door in enough to push in the switch. First check the alignment of the door. If the door is low, try bending the hinges back up. Open the door just enough to get your fingers inside the bottom of the door and slowly pull up. If the door is better aligned it may push the switch in better. Close the door and try the dryer.Next try holding the door in with one hand and pressing the start button. If the dryer starts every time while pushing the door in, then the latch is worn and should be replaced. I hope this solves the problem.
Good luck
Nov 29, 2014 | Kenmore Dryers
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
Kenmore dryer will not start. is it the door
since to push button is a contct relay,
i would suspect, the door switch first
Oct 13, 2009 | Kenmore 62602 Electric Dryer
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Dryer only runs when "push to start" lever is held. stops when you let go. is this the motor switch causing this?
In a normal situation, when you push the start button, it activates the relay to hold on the circuit until it is interupted: for example you open the door. The relay cannot activate by itself until an initiation by the push button. If the relay is not working to hold the current then then holding the button to keep motor running is what happenes here. Your relay need to be replaced.
Jul 09, 2009 | Dryers
Dryer problem
with power disconnected
follow the wires from the start button, to a relay,
check the wires (both ends) of all leads to the relay and reconnect any that have fallen off. (crimp tighter if they have fallen)
Check door switch function and connection.
check timer connections
the relay start-button timer and door switch comprise a latching circuit, when the start button is pressed the relay is supposed to latch closed and supply current to heater and motor. if the latching circuit disconnects the relay does not latch closed, and only runs as long as the start button is pressed.
if nothing has disconnected one side of the relay has usually failed, and the connection is not being made to latch the circuit
replace relay
cd48320.jpg relay is shown at right, 2 switches connected by a dashed line.
Oct 12, 2008 | Kenmore 62602 Electric Dryer
Faulty Start Button?
If the dryer doesn't even start to turn when you press the start button, then you have to look at a couple things; The start button itself, the starting relay or the safety circuit. You mentioned that there's a ticking sound... if this sound goes away when you open the dryer door but comes back again when the door is closed, then the safety circuit is working.
It could be the switch itself or the starting relay (if equipped with one). If you're mechanically capable, consider looking at the relay. See if the contacts are being pulled in when the start switch is pressed (DANGER: HIGH VOLTAGE). If it is, the start switch is OK.
Hope this helps.
Apr 02, 2008 | Dryers
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Dryers Logo
117 people viewed this question
Top Dryers Experts
