Question about Kitchen Ranges
Igniter has loose wire but can't figure out where it goes. grill was purchased already assembled. it sparks on the bottom only
Bought a brinkmann proseries 9415 from walmart already assembled. there is a loose wire on the igniter but cannot figure out where it goes. it sparks on the bottom but not on the top. it has a small white plug in on one end. can you tell me where to plug it in at?
There is a little pin on the bottom of the side burner it plugs into.
Posted on Jun 10, 2009
My ignitor wire came out on my Brinkmann Gas Grill
it should just push back on lok at the end of the wire there is a connection on the end round or flat this goes back on to the back of the knob
Apr 21, 2012 | Gourmet Grilling
Brinkmann Pro Series 2545 Assembly - The side burner valve nozzle does not fit firnly into the burner venturi. The venturi (pipe) is about 1 inch too short!
When you attached the side burner assembly to the grill frame, did you pull it forward before tightening the 4 bolts that hold it in place? If not this could account for part of the problem. The other would be how you routed the gas line hose from the 'Y' connector, to the side burner connection. If routed differently than what the assembly instructions indicate, you would come up short on the length.
In any event, your model grill has been discontinued by Brinkmann, but the warranty and some parts are still supported by the manufacturer. I'm assuming you just purchased this grill and are in the process of assembling it according to the Owners Manual. So, if you continue to have a problem contact Brinkmann's Customer Support Hotline 800-527-0717.
Hope this helped you. Please let me know. Thanks.
May 14, 2011 | Brinkmann ProSeries 810-6330-W Grill
PRPOANE GAS REGULATOR ASSEMBLY BROKEN. MODEL# 842-0200-0
The model number 842-A250-0 does not match any Brinkmann gas grill models in my data base. However, if yours is a standard gas grill, that uses a 20lb LP tank, you can purchase a hose/regulator assembly at any home center or hardware store that sell gas grills and accessories. Make sure to take you old one with for comparison purposes (ie hose length).
Further, if you regulator has GDA on it. It was recalled by Brinkmann during a voluntary Safety Recall. If your regulator hasGDA on it, contact Brinkmann Customer Service (800) 675-5301 between 8:30 a.m. and 5 p.m. CT Monday through Friday. They will provide you with a free repair kit. You must provide and accurate Model Number & Serial Number of your grill, to take advantage of this Safety Recall.
Hope this helps you find the hose/regulator assembly you need. Please let me know.
May 05, 2011 | Brinkmann 842-A250-0
Everything is working fine.....I see a flame on the ingnitor...when I put in a match it lights... When I try to ignite it wiht the dial the spark is not getting fire.....the ignitor seemed to fall off...
The ignitor or as Brinkmann calls it, the Collector Box (it collects gas for the ignitor to light it) attaches to the inside of the front of the burner or grill box to the right of the first burner on the right. It attaches with a screw (which apparently had fallen out). I have included a link to your Owners Manual, which shows a drawing of your frill head, looking down into it from above on Page 26. This should visually help you.
http://images.brinkmann.net/docs/pdf/810-8410-S.pdf
One more thing. Brinkmann has discontinued your model. A limited number of parts are still available through Brinkmann, so take good care of your grill.
Apr 30, 2011 | Brinkmann 810-8410-S Stainless Steel...
I bought model#810-2545-w from walmart and my dogs ate the manual before I could assemble grill. How do I get a replacement manual?
You can go to Brinkmann Corp website and download the manual or cal their Customer Service Detpt.
http://www.brinkmann.net/home.aspx
Good luck & Happy Grilling!
Mar 18, 2011 | Brinkmann Grilling
The ignitor would not even click. put new batteries with no success.
Make sure that you have the battery facing the right direction. Generally on most electronic grill ignitors the + end should be facing you. If you're sure they are facing the right direction, remove them and check for corrosion in the battery holder. If you find some, clean it out using a Q Tip and WD40. Then replace the battery. If that doesn't solve the problem, make sure all the wires behind the control panel of the grill are securely attached. Then remove the cooking grates and the flame tamers and check the spark ignitors, If they are covered with grease, which they frequently are, clean them with a cotton ball soaked in alcohol.
Any or all of the above should solve the problem. If it doesn't, it's time to replace the electronic ignitor assembly. You can purchase it online directly from Brinkmann.
Happy Grilling!!!
Mar 08, 2011 | Brinkmann ProSeries 810-6330-W Grill
Where does the ignitor battery go on the Brinkmann model 810-9520-S grill?
It goes inside the igniter button holder. Unscrew the outer plastic ring of the igniter button and you'll find the holder under it. Usually takes 1 AAA battery. But depending on how old yours is, it may take 1 AA Battery.
Jan 19, 2011 | Brinkmann 810-2300-B Grill
New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
Apr 25, 2009 | Grilling
Igniter problem
right in front where the red botton pushs in to light! grab the ring around that and un screw it!
Apr 04, 2009 | Brinkmann 810-2300-B Grill
I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Mar 19, 2009 | Grilling
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
