My washing machine BOHAG makes too much sound while rotating. Some times while pulsating also some sound as if the durm is touching somewhere(like tuck tuck). Why is this?
    Problem Solver:
  • 11 Answers
You must see with light inside if you can see some thing dirty inside or you need to change the bearings if the machin has mor than 5 yars.
Posted on May 12, 2009
Why do the lights throughout the house pulsate when the washing machine starts agitating?
What make and model washing machine? How far is the breaker box from the washer?
Mar 24, 2017 | Washing Machines
Power comes on but will not start wash cycle justs sit there and humms
Try the steps below:
- try running it without any load to see if it still hums.
- if it does, see anything underneath the pulsating disk if there's anything stuck. (like a coin or a pin)
- if it doesn't, You can also try removing the belt between the motor and the pulsator to isolate if it's a defect in the motor or the pulsator.
After that, If the motor is defective, then you'd have to replace that or repair it if you know how to. If the pulsator is defective, check again if there's something stuck in the bushings. If you've used the washing machine for quite a long time, you may need to replace the bushings and bearings of the pulsator. You can also buy an assembly unit for the pulsator if there's one available in your area.
Hope this helps.
Jan 27, 2011 | Washing Machines
We have a Maytag Neptune Washer Model MAH-1, approximately 5 years old. Never had any problems previously. Last wash, noticed a loud grinding sound upon starting the cycle. I stopped the wash, and...
Sounds like the spider arm(s) are broken in your machine. It is the part that supports the wash drum in the machine. It's a major repair job and can be expensive to fix. Get a few estimates before deciding whether it is worth fixing or replacing the washer.
Oct 05, 2010 | Washing Machines
Displaying LE
Lg has a water pulsator which rotates while filling up with water. If pulsator is faulty, you will get this LE indication. Pulsator is found on bottom left hand side of unit when cover is removed. 2 clear water pipes are connected to it and there is a small plug in that has 2 wires. Remove plug in first then remove from the pipes.
Sep 21, 2009 | LG Washing Machines
Durm is not rotating
replace the drum drive belt
Aug 31, 2009 | Frigidaire Washing Machines
LG top loader slapping noise in wash cycle
Its not the usual problems found on Lg machines. sounds like you have possibly one or more coins being picked up underneath the pulsator. To check, remove pulsator with screwdriver and check .Very possibly you have a bra cup spring caught between the two drums which make an akward sound.
Jan 27, 2009 | Washing Machines
My washing machine
Open washer's rear panel and look for a released or a malfunction shock absorber Good luck!
Aug 27, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
