Question about Cosco Alpha Omega Elite 5-Point 22-155
Removing seat cover
My grandchild vomited in her car seat and I would like to remove the cover.
I can't seem to figure it out.   Help!!!!!
  • 3 more comments
  • Anonymous Jan 06, 2008
    ive tried removing all straps everything please help
  • Lesliegt May 17, 2008
    I'm having trouble getting the cover off too. What about those plastic parts that the strap goes through and hold the fabric to the seat. Do they pop out or do you have to pull the fabric out?
  • rainytosunny Jun 18, 2008
    The manufacturer does have the instruction manual for this car seat on its website. You have to enter a product number and manufacture date (both listed on a sticker on the side of the seat). http://www.coscojuvenile.com/instruction... The directions for removing the fabric cover are toward the end of the manual. You start by removing the base and the straps. I needed a wrench to loosen and pull out the metal bar in the bottom of the base (pushing on a tab at one end of the bar to allow it to slide past). Then you just squeeze the red recline handle and the base comes off. The straps themselves come out fairly easily, but not the plastic guides that the straps go through. The manual says to squeeze the sides of each guide together from the back while you pull from the front at the same time. I had to use pliers to do this. They didn't break, and it wasn't nearly as hard to pop them back in again when I was done. Once you get the four strap guides out, you can work the cover off. I'm still not clear on how to remove the headrest that slides up and down, but luckily my child's unmentionable stuff didn't touch that part. I was able to remove and wash the parts that mattered (straps and cover).
  • Anonymous Jul 15, 2008
    I removed the cover to my Cosco Scenera 5-point convertible car seat and can't put it back
  • glminneman Aug 06, 2008
    I took the liner out of my grandchild's seat to wash and now can't get it back correctly. The idea of taking pictures is a good one if you read the idea before you have the problem.
    Scholar:
  • 58 Answers
Dorel Juvenile Group manufactures these car seats for under the Cosco brand. You should check out their web site.
  • Check out the recall notices and make sure your seat is not listed.
  • Register your car seat so that you are informed of any future recalls.
There does not seem to be any Manuals on their website, but they do list a phone number. 1-800-544-1108
When I took mine apart I did the following.
  • Take many pictures of it first so you can see how it goes back together.
  • Put all of the parts in a container so you don't lose any.
  • Start by removing the screws on the headrests. There are four of them.
  • Using a flat screwdriver on the left side and a pair of pliers on the right (as you are facing it) pull the metal rod from the hinge to the right. Make sure you don't damage the springs.
  • The screwdriver can be used to gently pry the square metal strap anchor from the plastic holder. It is tight!
  • Then fish the anchor through the seat and fabric.
  • The shoulder straps have to go from the front through the fabric.
  • There is a front clip that is located between the child's legs. I had to finesse the fabric cover around this.
I think that is all I did. We washed the cover in COLD water on delicate and soaked it overnight to get it clean. Hang dry!
Posted on Nov 16, 2007
Tgrfhgfhbgfbgfbgtbhrgthryh
Posted on Apr 05, 2008
  • 3 Answers
I have car seat model 22158-GRS Alpha Omega Elite. I just had to remove the pad and wash it. The following manual helped me. Pages 40-44 are the ones to be looking at.Car seat Manual
Posted on Apr 16, 2012
Third row seat latched on left but not right
I just ran into the exact problem with my 2004 Suburban. Once I got the seat to lay down all the other mechanisms worked as they should and I could get the seat in and out as usuall. I found this post below which explained how to get the seat down. Wish I could take credit for figuring it out on my own but I can't.
"After working on it for a couple of days here is what I did to remove the 3rd row seat.
On the rear lower right and left side there are plastic covers, if you push the seat material forward a little you can see a hole where a nut holds it on, remove the nut. On the left side pull back the plastic cover and you can see the wire and the lever that releases the seat. With my foot holding up the #1 release lever on the right side I used an open end wrench to push forward the left side lever and the seat folded down.
I then used the #2 and #3 levers to remove the seat.
To view the whole cable, open the lower seat cover, it is an overlapping plastic clip, My problem was a loose cable, similar to a brake cable on a bicycle, after fixing it I have had no problems."
To remove the nut I used an 8mm socket wrench. My problem was not a loose cable but the #1 mechanism wouldn't pull up all the way, I'm guessing because that left side locked in out of order. I pushed that left side lever down with a hard tool and had my 5yr old daughter pull up on the #1 and the seat folded right down.
Hope this helps if you havn't already gotten it fixed.
Apr 23, 2013 | 2000 Chevrolet Suburban
My daughter puked all over her car seat and I need to wash the cover. The instructions say I have to remove the base and the harness to get the cover off....I can't for the life of me get the base off! ...
I imagine you've already fixed this problem by now. I have two of these car seats and it took me the longest time to figure it out. If you still need help, let me know. You're right, the instructions aren't as easy as they seem.
Jan 28, 2011 | Safety 1st Alpha Omega Elite 22456 TTN...
How do i take the back off on a 1999 nissan maxima bucket seat
Hi, follow the instruction below......
Rear
See Figures 3, 4, 5 and 6
  1. Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
  1. Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
  1. Remove rear seat back by tilting forward and pulling straight up.
To install:
  1. Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
  2. Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
Jan 19, 2011 | 1999 Nissan Maxima
Replace seat belt on 2000 nissan frontier
Should be a T50 or T55. Should have a cover over the bolt. Remove the cover, and remove the bolt.
Jun 09, 2009 | 2000 Nissan Frontier
Seat Cover in Pontiac Montana
Not sure about the storage bins BUT,if you have side airbags in the seats make sure the seat covers are "side airbag" compatible.
Jun 01, 2017 | 2005 Pontiac Montana
I need help removing 97 sable headrests
at the base of the head rest there should be a tab that you can push in that allows you to remove them.
Apr 17, 2009 | 1997 Mercury Sable
Seat Belt repair/replace
  1. Remove front seat.
  2. Remove adjuster cover. A
  3. Slide floor anchor cover.
  4. Remove floor anchor bolt. B
  5. Remove shoulder anchor bolt. C
  6. Remove front and rear kicking plate, then remove center pillar upper and lower garnish.
  7. Disconnect seat belt pre-tensioner connector.
  8. Remove the screw securing seat belt pre-tensioner retractor, then remove seat belt and seat belt pre-tensioner retractor.
  9. Remove bolts securing seat belt adjuster, then remove seat belt adjuster. Reverse procedure to install.J
Nov 03, 2008 | 2000 Nissan Maxima
How do i remove my car seat cover?
Go to the manufacturer website and enter the information requested. I was going to do it for you, but you must have information from the label on your seat to go further.
http://www.coscojuvenile.com/instructions/
The user manual is downloadable. My son used to get car sick and did the same to me, what a mess.
Good Luck! from Moms Just Know
Oct 22, 2008 | Eddie Bauer Deluxe High Back Booster...
I have a Graco infant car seat and want to remove the padded seat cover to place in the laundry. There are two elastics on either side of the car seat that help secure it to the sides of the handle. I...
What model do you have?
You can call graco at: Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Ensure you do NOT wash the straps/harness, as it will make it unsafe and you will need to replace it.
They also have an online manual fi that will assist you. I checked my seat, and it is an older snug ride with no straps.
Thanks
Apr 30, 2008 | Graco SnugRide - Giselle Infant Car Seat
Maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Jan 08, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Cosco Alpha Omega Elite 5-Point 22-155 Logo
6,556 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
