Question about Whirlpool Washing Machines
Whirlpool hd wm 1100 controls locked - Whirlpool Washing Machines
This is mentioned on the front Panel. Simply Look at the Text Under the DRAIN/SPIN button on bottom right of the HD WD 1100 where it says:-
press & hold 3
seconds to Lock/
Unlock controls
JJ
Posted on Oct 03, 2009
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
My clean light is flashing and the lock light is on, on my whirlpool dishwasher. I've tried the reset code of HD/N/HD/N and it didn't work! What can I do?
What is the model? If you take the panel off you can test the control board and controller by unhooking the ribbon cable from the controller to the keyboard. Then close the door. If the pump comes on, it is the control panel, if the pump does not come on it is the control board.
Jun 04, 2013 | Dishwashers
My oven locked while cooking and will not open. Says e2 f3
Oven temp too high. Check sensor. Should be around 1100 ohms and not grounded to frame. If the sensor is ok then the control relays are fried.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 05, 2010 | Whirlpool Ovens
How to check the water level switch with ohmmeter
Water level switch is pressure controlled. water enters the drum creates a pressure/ this then turn off water valves. most likely blockage in feed pipe /hose to the switch, you can blow Gently into switch to hear it operate..Advise clean to hose and or chamber ....
Nov 11, 2009 | Washing Machines
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpoo? duet displays F11 and F dl alternatively
F11 IS A COMMUNICATION ERROR BETWEEN THE DOOR LOCK ASSEMBLY AND THE MAIN PROCESSING BOARD THIS HAS BECOME A COMMON ISSUES WITH THE DUET WM THAT WERE MADE BETWEEN 2003 TO 2006. THERE IS A HAIR LINE CRACK IN THE MAIN BOARD THAT IS CAUSING THIS ISSUE. MFG SUGGEST CHANGING THE MAIN BOARD AND THE DOOR LOCK ASSEMBLY
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door lock
if you cannot get to it by just reaching between the rubber rim.
The official way is to take off the top and bottom access panels , 3 screws on each in top rear and on the bottom front, then remove the front control switch panel.
then you can remove the front of the machine.
Feb 27, 2008 | LG WM-1090FHB Front Load Washer
Washing Machines Logo
414 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
