Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
Majic Chef Freezer is collecting water at ...
By mikeymike on Oct 13, 2007
I have a Majic Chef side by side model CSD2123AR and the coil in the back is getting hot but the water hits the small almost flat pan under it and it rolls down into the base of the freezer forming ice buildup and eventually runs out the door.
Any help would be so much appreciated as we need to put a new floor in but can't until we resolve this and financially we cannot afford a new Fridge.
thanks!
Comments:
Oct 30, 2007
- Thanks soooooooooooo much for your help the issue is resolved because of your wisdom.
You have saved my family a financial burden we could not have afforded.
Again thanks and god bless you!
Best Solution
posted on Oct 14, 2007
Very Helpful)
fridgetech
Rank: Guru
Rating: 88%, 961 votes
At the back bottom of the freezer there is a drain.  It is frozen.  Remove the rear bottom panel in the freezer.  Break up the ice (I use a small putty knife) and get all of it out including the ice on the bottom of the freezer floor.  Run HOT water over the drain until it drains freely to the pan underneath and your problem is solved.  Whirlpool makes a heat probe that connects to the defrost heater and sticks down into the drain hole that helps prevent this from happening again.  The part # is 819043 ($9-$13).  The heat probe is about 4-5 inches long so it depends on how close the defrost heater is to the drain hole.  If you look at this diagram the defrost heater is # 12.  I have seen people use a metal clothes hanger as a substitute but hanger must be tight around heater.  This keeps that drain hole warm.  Let me know if you have any other questions.
Comments:
Oct 14, 2007
- Look at diagram for freezer compartment which is # 4 in left hand column.
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
the samsung four door quattro refrigerator
Answer
Amana side by side frig 85127
Answer
ice maker keeps making noise and ice model mg s 2326cedw/4 how does it know when to stop could it be... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Refrigerators:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
