Question about BenQ FP71G 17" LCD Monitor
My lcd monitor lights in green but does not display
When i start my pc, the lcd monitor turns in orange as usual and then in color green which means that the hard disk is okay and the operating system is already loaded into memory but the lcd displays nothing
  • BenQ Master
  • 2,404 Answers
That is definitely not normal. Try a different monitor on the computer and if you get video on the new monitor then you know your original monitor is bad for sure.
Sounds to me like its a problem with the lcd or the inverter. You might want to try and take apart the monitor and reseat both ends of the LCD cable. If that doesn't help then the monitor is faulty and you'll have to get another one.
Posted on May 31, 2009
Does not turn on
Hello
With any monitor, check the following to determine if the issue is MONITOR related or COMPUTER related.
1. Verify the monitor is receiving power - use a known good power outlet and plug it into the monitor
2. Samsung monitors have a light on the power button - are you getting any color light from this? Orange means it is in "stand by" mode and is waiting for the PC to send it a signal. Green means the monitor is getting a signal from the PC and the monitor is on.
3. With the monitor on, press the buttons on the monitor to bring up the OSD (on screen display) that changes the monitor settings. If you have a green light on the power button and press one of these buttons (AUTO works best), this will display the monitor adjustment options on the screen.
If you see the on screen adjustments, your monitor is working and the issue may be with your PC. Move the monitor to another PC and verify the monitor is working correctly.
IF you don't see anything on the screen and the power light is green, the monitor has failed.
This could be the lights that illuminate the screen have failed (something that happened to my Samsung Syncmaster monitors after about 6 years of use) or the screen has stopped functioning. In either case, replacement parts are hard to find and a monitor swap is likely.
Nov 03, 2013 | Samsung SyncMaster S22B150N - LED monitor...
My monitor won't show the display even though it is turned on
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card. When the PC turn on there is any beep. If no beep then your RAM is alright. Problem in VGA Card.
Mar 21, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Problems with screen display colors
If you seeing an absence of greens it usually means your connector at the back of the flat panel are not tightened firmly. Use a screwdriver to get them snug. The same goes for the connector at the back of the PC.
May 09, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
No display on monitor only orange light
Normally the orange light should turn green when everything is a go. Often the problem of orange light is not really the monitor but the PC. There is not video output from the video card and the monitor in sensing this assumes that the cable is unplug and thus does not switch on (green).
The sure way of determining which is at fault is to try and use a different monitor to your PC (as well as the cable). Should problem persist, then it is the PC that would need to be checked. On the other hand, if the PC works with another monitor, then you have just verified that indeed the monitor is defective.
Should you have verified that it is the PC, suspect would either be the video card and/or the memory sticks. In some instances cleaning with a pencil eraser the little gold pins of either the video card and/or the memory sticks helps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 26, 2008 | AOC LM 720 17" Flat Panel LCD Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
411 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
