Problem for Dryers
Generic problem for all Dryers
Loose drum support felt
I notice that the dryer was making noise with the turning of the drum. I opened up the top of the dryer and found that the felt strip that the drum rides on has come loose. It appears that plastic studs that were used to hold it in place have sheared off. Is there a way to resecure the felt to the housing without new plastic pins?
Same Problem
Nov 04, 2007
-   I am having this same problem. The drum appears to be loose when the dryer is running. How do I fix this? I didn't see any plastic parts missing or broken as previously described, it just is loose.-
tknudson
Solution #1
posted on Oct 14, 2007
Rank: Wiz
Expert
Rating: 84%, 1092 votes
you could try using "Permatex" hi-tack adhesive. you need to remove the door where the bearings are first.
Popular Solutions for Dryers
Kenmore 73952 / 73954 / 73956 Gas Dryer
1 Solution
Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric...
1 Solution
Questions and Unsolved Problems for Dryers
I am thinking of buying a Kenmore 600 Series TL Dryer QP2 or the 700 Series. Can anyone tell me if...
(More)
I am thinking of buying a Kenmore 600 Series TL Dryer QP2 or the 700 Series. Can anyone tell me if these are good models or if there is any problems with them. Thanks...Jan
how do i troubleshoot my kenmore model 110 electric dryer. it does not heat while it tumbles. How do...
(More)
how do i troubleshoot my kenmore model 110 electric dryer. it does not heat while it tumbles. How do I know for sure that it is the heating element.
my dryer was working fine, only 2 yrs old, will not turn on checked outlet, breaker and door, just...
(More)
my dryer was working fine, only 2 yrs old, will not turn on checked outlet, breaker and door, just quit for no reason at all
my kenmore model 96575100 is not turning on at all -worked yesterday any hints - could it be the...
(More)
my kenmore model 96575100 is not turning on at all -worked yesterday any hints - could it be the button that turns it on is not connecting?
