Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Middle spray arm does not rotate
Top one does and they are fed by the same water source.
  • 27 Answers
Please check: Does the arm turn freely?  Are the jets clean and spray in the right direction? If not you may need to replace the arm.
Posted on May 12, 2009
The middle spray arm isn't rotating
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 04, 2011 | Frigidaire Dishwashers
The unit goes through its cycles but the top rack is not getting clean. The bottom spray wheel works, the middle and top spray arms are getting water but it seems not enough to make them rotate. The pump...
The problem is likely to be that the jets in the rotor arm are blocked.
To check this, remove the arm (it is easy to do, as it is intended for the user to do this) and clean out all the holes. Try running water from you tap through the holes (backward flow) to remove anything that is too large to pass through the jets.
Sep 26, 2010 | Dishwashers
Seal round door leaks
If the water is noticed at the bottom of door it is probably the seal at the bottom (very unusual for the tank seal to leak, however it is just pushed in, so you could take it completely off, give it a clean up and put it back in) or one of the spray arms is restricted and instead of rotating the water is spraying continually at the corner of the door. Check all hole in the spray arms are clear and if you have a dishwasher freshener make sure it is not stopping the top spray arms rotation field. You could also check that the top arm is clear to move when your dinner plates are in the bottom basket (the top basket could have been moved inadvertently to the lower level).
Hope this gives you a starting point for checks.
ps bottom door seal is quite tricky to replace, so you may need to get an expert is the above tests indicate that that is the leak source.
Jul 11, 2010 | Bosch Dishwashers
Dishwasher is running but dishes aren't clean
sounds like the top or middle spray arm isn't rotating, most likely a clogged spray arm, try and remove sprayer arm and clean it
Aug 22, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Top spray arm does not rotate, is mechanically
try checking the water holes in the arm, as when they spray out the arm turns. If they are blocked in any way it does not turn, try using a needle to check they are clear.
Aug 07, 2009 | Electrolux Kenmore 24 in. Built-In...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
The diswasher arm does not rotate or spray water
Check the small holes on the spray arm. They are most likely plugged. (candy wrappers, tooth picks, popcorn or watermelon seeds, you name it.) Sometimes you can clear the holes out, other times it is just as easy (and not very expensive) to replace the spray arm(s). List your model number if you need part numbers or instructions on removing spray arm.
May 14, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
My Bosch dishwasher model #SHU43C05UC/14 drains well and has enough water(I replaced the inlet water valve already),but not washing the dishes clean especially the top rack.What could be wrong?
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Jul 14, 2008 | Dishwashers
Baumatic BDW13
I think that you may be on the half wash setting, check to see if the light labeled as number 4 is on while washing, if it is, then you need to simple turn off this option. Let me know if it isn't.
I will provide further assistance if needed, just let me know
otherwise Thank you for using Fixya, good luck and please don't forget to rate my solution when you solve the problem
Apr 24, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
... calling Master_Tech Bosch Dishwasher SHU43C07UC
Hello Mary, I checked on your dishwasher and what you have is a pressure fill dishwasher. This unit has a pressure switch to make sure the water level is correct. When the dishwasher is full of water (the indention that is around 2 inches in from the side walls and front) is where the water level should be out to. If the water isn''t out this far, then the pressure switch is shutting off early and not filling properly. I read your entire essay, it is perfect, so this sounds like an issue of either not enough water, or the circulation pump impeller has separated and not creating enough water pressure at the wash arms. Since you stated that you removed and cleaned the filters, that shouldn't be the issue. That is normally where I find this issue at is clogged filters, espically in hard water. I have seen results in the pass where too much detergent was used causing the pressure switch to shut off early. In those cases filling the detergent dispenser with cooking oil and running the longest cycle removes the excess detergent. It is proteins that the detergent is designed to break down. So quit worring about your water pipes, the issue is with the dishwasher. Hope this helps.
Feb 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
154 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
