Question about Frigidaire FSC23F7D Side by Side Refrigerator
Side by side ice and water dispenser
The light in my water and ice dispenser needed to be replaced. When I replaced the bulb the bulb blew and I lost all power to my dispenser panel.
  • podrum Oct 13, 2007
    This is a model number MRS26LGJ and is about 7 years old
  • podrum Oct 14, 2007
    I have found the fuse any suggestions where I might buy one and also a 4 w bulb. Lowes and home depot do not stock even though they sell the product.
  • 363 Answers
Did you replace the bulb with one of the same voltage rating?
Seems strange that a new bulb should blow straight away, maybe it was faulty.
This sounds like a blown fuse.
Posted on Oct 13, 2007
  • Martin B
    Martin B Oct 13, 2007
    Get the parts catalogue here
    It shows an exploded view of the dispenser panel.
    Look at page 14 part number 83, this is a 7A fuse that you should be able to replace easily.
    Good luck
  • Martin B
    Martin B Oct 14, 2007
    I dont think there is anything special about the fuse or bulb.
    Try a smaller electrical store or domestic appliance repair shop, they will know exactly what you are talking about.
    You'll need to take the 7A fuse because theres 3 or 4 different lengths and also the bulb which is 115V,4W but the guy will need to see the screw size.
    A spotty teenager on customer service at Home Depot will NOT be able to help :)
    Thanks for the rating.
x1 sonny ericcson widows mobile 6.1 version i want to change my language to english
Jan 05, 2014 | LG LSC26905TT Side by Side Refrigerator
Ice dispenser stopped working. How can I tell it the motor blew?
look for spare part and replace it. Several site which sell spare parts.
Dec 14, 2017 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice dispenser won't work, light won't side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Night Light...
look up inside the water and ice dispenser and after you see the bulb...replace it with same.
Apr 01, 2009 | Amana ARSE66MB Side by Side Refrigerator
Smart light not sensing darkness
there is a small pc board right there in the front panel it sontrols everthing from the light to the water and ice despensing . there are a lot of problems with this board and there not cheep from 65.00 to over 100.00 . i would wait untill another part of it fails ,and it will your water will go out ,or your ice . then you will be forced to replace it most only last 5 years ( new refrigerators are only lasting 7 to 10 years ) good luck
Mar 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice/water dispenser "shorted" out
You will have to get dispenser control outvto see what wires and switches may be burnt.
Nov 03, 2017 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
No lights inside or in water/ice dispenser as well as water/ice dispenser not working
Hi again,
For some reason I lost you on the Chat/Live Session. Allow me to repost:
  • possible source of parts - here or here;
  • breakdown of parts location/diagram - here;
  • a reference only schematic diagram - here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Maytag MSD2756G Side by Side Refrigerator
Ice & water dispenser not working
The control board is likely gone bad or a wire harness inside the front came loose. With all those indications, I'd lean toward a dead board.
Jan 07, 2007 | GE PSW26SGRSS Side by Side Refrigerator
Frigidaire FSC23F7D Side by Side Refrigerator Logo
258 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
